Does the Drag 3 Kit required block cutting?
Old Nov 29, 2001 | 06:44 PM
AllMotorITR's Avatar
New User
Default Does the Drag 3 Kit required block cutting?
I am considering installing this turbo in my R.. I heard it requires my block to be cut, major mods.. Is this true?
Old Nov 29, 2001 | 06:47 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Does the Drag 3 Kit required block cutting? (1 FAST R)
Depends on the manifold and some other things, if it is a premade kit chances are they've already done the majority of the things to make sure it would work. Be sure to ask any of the dealers though before actually buying it, I think the drags you may have to cut though, don't know about the others.
Old Nov 29, 2001 | 06:50 PM
integra7's Avatar
New User
yes, had to cut the block to clear the compressor housing......thats drag III on a gsr...
Old Nov 29, 2001 | 06:53 PM
lazyvietboi's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (integra7)
who did the cutting for you??
is there alot of cutting?
Old Nov 29, 2001 | 07:03 PM
integRated109's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (lazyvietboi)
you have to grind about 1" square out of the webbing around the block. not too major, just get a good grinder wheel, doesnt take long.
Old Nov 29, 2001 | 07:19 PM
TurboITR's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (integRated109)
yes
Old Nov 29, 2001 | 07:27 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you use a Drag 3 with a TO4B you will not have to cut the block. Its the TO4E compressor that will hit it because its really big.
art
Old Nov 29, 2001 | 07:29 PM
New User
Default Re: Does the Drag 3 Kit required block cutting? (Arturbo)
Since I'm new to turbo, does the size of the compressor make a power difference? Which is a better choice for more power?
Old Nov 29, 2001 | 07:32 PM
the T04e is really big, and will make really big power.....most likely more than you will ever be able to use. im sure ill never even come close to maxing out this turbo.
Old Nov 29, 2001 | 07:44 PM
PureTeg420's Avatar
my drag manifold was angled, so i didn't have to notch any of the webbing off. This is a drag 3 on an LS
Old Nov 29, 2001 | 07:48 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Does the Drag 3 Kit required block cutting? (PureTeg420)
That is correct becaue the Drag 3 for the Civic Si and Ls come with a TO4B compressor housing. Now, since you have a ITR and you do not want to shave the block webbing, then you can order a to4b with the kit.
art
Old Nov 29, 2001 | 08:44 PM
Flamenco-T's Avatar
get a 3/8" drill bit and a electrical drill, I cut about 1" off the block and still have about 1/3" clearance between the compressor housing and the block...
then use a smaller bit to cut the sharp edges left by the bigger bit
it only took me about 15-20 minutes to get it done, afterwards use a grind to smooth the edges out...
no biggie...
Old Nov 30, 2001 | 12:13 AM
Ben Huynh's Avatar
The way you clock your turbo will also determine whether or not you have to grind down your block.
Old Nov 30, 2001 | 01:00 AM
liam821's Avatar
25 Year Member
Default Re: Does the Drag 3 Kit required block cutting? (ben@importparts.com)
i just helped my friend install a custom kit on his b16a. We had to modify the block a little. We did all the work ourselfs..took about an hour or so.
...here are some pictures...
liam
Old Nov 30, 2001 | 03:59 AM
MiraiZ's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (liam821)
eeek...you guys are brave!
Old Nov 30, 2001 | 06:57 AM
PROFILES2000's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (MiraiZ)
i had to do the same thing. rev hard kits are the same also
Old Nov 30, 2001 | 07:08 AM
jamal-188's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (PROFILE GSR)
I've heard some people say they didn't need to do it. It's not that big of a deal, not like you're messing w/ the internal or anything.
Old Nov 30, 2001 | 07:36 AM
quick108's Avatar
Default Re: Does the Drag 3 Kit required block cutting? (jamal-188)
Like Ben said, it all depends on how you position the housings. When I first installed the kit, I didn't need to modify the block. When I built the motor 2 years later, I decided to turn the compressor a tad CCW. After I finished the install and cranked it, I noticed the shaft in the turbo was stuck! So I cut the block with a small hand saw with the turbo still in tact.
-JP
Old Nov 30, 2001 | 09:20 AM
GSRacer's Avatar
New User
Default Re: Does the Drag 3 Kit required block cutting? (quick108)
had to cut mine. it's not a big deal. used a grinder.
sfwdcrx
Mar 19, 2008 02:33 AM
gsrboost
May 5, 2005 09:14 AM
ceemarun
Jul 3, 2002 11:08 AM
FredoSP
May 12, 2002 08:05 PM
intekragsr
Jan 27, 2002 06:38 PM
