Drag 3 Block Shave?
Old May 11, 2002 | 09:27 PM
FredoSP's Avatar
Default Drag 3 Block Shave?
I was wondering exactly where you need to shave part of the block during the drag 3 install on a Si? Im looking into getting this kit, so I wanted to have an idea before I took on the task, PICS are welcomed!!
Old May 11, 2002 | 09:45 PM
HXMan's Avatar
Default Re: Drag 3 Block Shave? (FredoSP)
I would like to know if I have to shave my block with the drag 3 kit on my b16.
Does anyone have the exact specs on the T3/T04B that comes in the drag kit for a b16?? Search used to bring up a post, but it doesn't work anymore.
Old May 11, 2002 | 09:53 PM
FredoSP's Avatar
Default Re: Drag 3 Block Shave? (Mad HXMan)
umm the SEARCH SUCKS, or haven't you noticed
Old May 11, 2002 | 11:00 PM
PrecisionH23a's Avatar
there is no shaving necessary if you install everything correctly.
Old May 12, 2002 | 12:14 AM
Mr. Vapor's Avatar
Default Re: Drag 3 Block Shave? (GudeH23a)
WRONG shaving is neccessary on the passanger side of the block, right below the block ID #, where it webs out, you need to shave about a 1/4"
its simple
Old May 12, 2002 | 12:24 AM
FredoSP's Avatar
Default Re: Drag 3 Block Shave? (NYb16)
Got any images?
Old May 12, 2002 | 12:34 AM
BoostedSi's Avatar
its simple
I didnt have to shave mine
Old May 12, 2002 | 12:42 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Drag 3 Block Shave? (BoostedSi)
It all depends what size your compressor is.
art
Old May 12, 2002 | 01:49 AM
intekragsr's Avatar
Default Re: Drag 3 Block Shave? (Arturbo)
to4e = shave
to4b = no shave
correct?
Old May 12, 2002 | 06:46 AM
I dont know what kind of turbo you are running because i have installed 2 drag gen 3 kits on a Si, and NOOO shaving of the block was necessary. period. if this guy is running a t3/t4, it requires no shaving. if you had the t3t4 and had to shave, you must not have rotated the compressor housing enough.
Old May 12, 2002 | 07:32 AM
HXMan's Avatar
art
If I only knew. Stupid Turbonetics turbo doesn't have any numbers on it except for things that look like serial numbers.
Old May 12, 2002 | 12:51 PM
Mr. Vapor's Avatar
i have the "E" Trim, not the "B" trim = Shave
Old May 12, 2002 | 02:27 PM
dustin's Avatar
Umm, no. It depends on the compressor like Art said. t3/t4 ? t3/t04b ? t3/t04b? which trim housing?
Dustin
Old May 12, 2002 | 02:34 PM
HXMan's Avatar
Default Re: Drag 3 Block Shave? (dustin)
I have the T3/TO4b as far as I know. Yea, on me for not knowing.
Old May 12, 2002 | 02:36 PM
Arturbo's Avatar
Better than steak
25 Year Member
FYI, the Si kit comes with a T04B so no cutting of the block is needed...
art
Old May 12, 2002 | 02:37 PM
HXMan's Avatar
Yea, I knew the Si kit comes with that turbo, but I have no real way of checking, if only they stamped the trim sizes and such on the turbonetics turbos.
Old May 12, 2002 | 03:06 PM
Mr. Vapor's Avatar
art
Ben sent me a t3/to4e..........
Old May 12, 2002 | 05:21 PM
HXMan's Avatar
Did you request the t3/to4e?? I wonder what I got?
Old May 12, 2002 | 06:04 PM
Etylorcen's Avatar
I believe if you count the fins if it has 6 fins its a b and 7 is an e. Anyone?
Old May 12, 2002 | 07:53 PM
turbopimp's Avatar
Default Re: Drag 3 Block Shave? (Etylorcen)
Actually, it's the other way around... 7 blades = T04B, 6 blades = T04E
Old May 12, 2002 | 08:05 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Drag 3 Block Shave? (turbopimp)
The T04E has 6 main blades with 12 sub-blades... these blades are rather large, so they move alot of air. The T04B has 7 main blades and 14 sub-blades.. these blades are a little smaller than the T04E's so they spool quicker but dont generally move as much air.
hondaeg8
May 13, 2006 09:45 PM
gsrboost
May 5, 2005 09:14 AM
Gfunk176
Mar 5, 2003 08:07 PM
intekragsr
Jan 27, 2002 06:38 PM
AllMotorITR
Nov 30, 2001 09:20 AM
