8 injectors...
Old May 19, 2004 | 07:16 PM
DaveF's Avatar
Default 8 injectors...
ok i just got my 4 other injectors in my manifold. so i have a total of 8... 1600 cc injectors..
the 4 in the bottom ofthe manifold, will have no problem sealing.
on the top side of the manifold, the bottom of the injector has an o ring on it, i just stuck the injector inside the factory honda black o ring that fits into the intake manifold... anyone have any better idea's???? i think this is going to leak
Old May 19, 2004 | 07:48 PM
Timmay's Avatar
Default Re: 8 injectors... (Dturbocivic)
you have to much money
very sick cars and setups. hope the 8 injectors work out nice for you
Old May 19, 2004 | 07:51 PM
Drew Peacock's Avatar
Default Re: 8 injectors... (Timmay)
How much pressure are they going to under?
Old May 19, 2004 | 08:30 PM
11psiTurboSI's Avatar
Default Re: 8 injectors... (turbozxi)
I don't get why you need 8 injectors??? What's the advantage using 8 then 4 injectors???
Old May 19, 2004 | 08:35 PM
jmagner's Avatar
Default Re: 8 injectors... (9psiTurboSI)
isnt the top of the manifold the stock location for injectors? Can you explain the way you installed them a little more?
They make 3200 cc injectors I'm guessing they would be hard to idle somehow
Old May 19, 2004 | 08:38 PM
Default Re: 8 injectors... (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">isnt the top of the manifold the stock location for injectors? Can you explain the way you installed them a little more?</TD></TR></TABLE>Yes, I don't really see a problem unless under real extreme pressure, I guess they will be under a reasonable amount.
Old May 19, 2004 | 08:40 PM
Tony the Tiger's Avatar
I am sure you will have custom brackets fabbed to mount the fuel rail onto the intake manifold. Make sure you get a nice squish on the injectors and they should seal against any boost leaks.
Old May 19, 2004 | 09:11 PM
SeanEF's Avatar
Default Re: (Tony the Tiger)
what manifold is that? nice setup
Old May 20, 2004 | 08:11 AM
underpressure02's Avatar
I think the bottom o-ring can have a little play in it as long as you have the rail bolted down. I think you just want to make sure the top of the injector has a good seal. That is where mine leaked from.
I can't wait to see this thing try and idle for your street car.
Old May 20, 2004 | 08:20 AM
Mikes01GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I don't get why you need 8 injectors??? What's the advantage using 8 then 4 injectors???</TD></TR></TABLE>
Well being I run 1000cc injectors the idle is not very good at all. My car
sounds like a cammed 350...lol.....Using the 8 injector method allows you to
run 4 smaller injectors for perfect idle and driveability then having the other
4 come on at V-tec for all that additional fuel for those big boost runs. You
can also run all 8 all the time if need be.
Old May 20, 2004 | 08:53 AM
Perception's Avatar
Default Re: 8 injectors... (Mikes01GSR)
8- 1600cc injectors. That could only mean methanol
Old May 20, 2004 | 09:09 AM
VisualAutoMotoring's Avatar
Default Re: 8 injectors... (Perception)
Not a great pic but that's also an 8 injector setup
Old May 20, 2004 | 11:16 AM
SOUNDEFFECTS's Avatar
Default Re: 8 injectors... (PRojectSi2)
When you tap out all the power of 4 large injectors you need to either go bigger or put more in (8).
I ran out of fuel and haven't decided if I want to go bigger injectors then what I have now and hope I can get it to idle decent or go with 8 injectors of what I have now. oh ya and I have around 1000cc injectors idleing perfect on a Hondata so I not sure how much bigger I can go.
Old May 20, 2004 | 11:41 AM
SOHC_MShue's Avatar
man you have some nice cars and way too much money
totsie7944
Mar 3, 2008 07:09 AM
steinar
Nov 18, 2007 06:18 AM
VNTEC
Mar 4, 2004 03:11 PM
Aeka GSR
Jan 28, 2004 05:55 PM
austrian type-R
Oct 3, 2002 09:43 AM
