Dirt on your Balls?
Old Oct 6, 2003 | 02:32 PM
EMod Civic's Avatar
Default Dirt on your *****?
Of your Ball-and-Spring MBC - get your mind out of the gutter.
I took my car to a dyno for the first time Saturday, and was a little supprised that it was only boosting 6.5psi, when I thought it was set at 10psi. It's an autocross only car, and I really don't ever look at the boost gauge, so it's probably been over a year since I set it. I'm using a ball & spring setup with a small bleeder hole to allow the wastegate to close quickly. Anyway, when I got home and took it apart, I found that there was enough dirt on the ball that it wasn't sealing at all. I cleaned it up, and it's all good now, but I'm wondering how long it's been dirty and how often I should check it.
Has anyone else had a problem with the ball getting dirty on a MBC? I do run an air filter on the motor, but I doubt that it does a whole lot of filtering.
And if anyone's curious, my Turbo'd old school Civic D15a3 made a whopping 120hp at the wheels on a dynojet at 6.5psi. On a more positive note, it also had full boost and 140 ft lbs of torque at 3200 rpm, which is good for autocross.
-Chris
Old Oct 6, 2003 | 02:36 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Dirt on your *****? (EMod Civic)
I didn't even fell like reading the rest....corney!
Old Oct 6, 2003 | 02:40 PM
Bailhatch's Avatar
Default Re: Dirt on your *****? (HybridcivicLS-T)
never heard of that problem, good thing to check if I come across a low boost problem.
Old Oct 6, 2003 | 06:10 PM
xci_ed6's Avatar
Default Re: Dirt on your *****? (Bailhatch)
lets see more old school civic pics
-Dustin
Old Oct 6, 2003 | 07:16 PM
LSiTurbo's Avatar
Default Re: Dirt on your *****? (krustindumm)
Good Info about your *****! Im sure thats somthing no one really thinks about.
-Brian W.
Old Oct 6, 2003 | 07:21 PM
MiraiZ's Avatar
Default Re: Dirt on your *****? (LSiTurbo)
Just wash the dirst off of your *****, lube them up nicely, and you should be all set fpr action again
siis2fast
Aug 28, 2005 08:21 PM
chihuahuamanx
Dec 7, 2004 05:06 PM
SpdFrk
Jul 10, 2004 12:07 AM
turbotypeR@SPEC
Jul 5, 2003 06:35 PM
SlowB16
Apr 17, 2002 08:49 AM
