Difficulty of changing a tial 38mm wastegate spring?
Old 04-12-2004, 08:15 PM
PGT Driver's Avatar
Default Difficulty of changing a tial 38mm wastegate spring?
I am curious as to how hard it is to change a 38mm wastegate spring. I have one that is to large and need to drop to a lower PSI spring like .4 bar or something. Anyway i am just curious as to how hard it is to change the spring.
Old 04-12-2004, 08:17 PM
redboost10's Avatar
Default Re: Difficulty of changing a tial 38mm wastegate spring? (PGT Driver)
its a bitch, a little easier with three or four hands
Old 04-12-2004, 08:25 PM
TRE_'s Avatar
Default Re: Difficulty of changing a tial 38mm wastegate spring? (tgh99si)
yea it can be a pain if youre doing it by yourself, but if you have an extra set of hands its fairly simple.
Old 04-12-2004, 08:26 PM
Danger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">its a bitch, a little easier with three or four hands</TD></TR></TABLE>
very true , one or two extra hands will make it easier
Old 04-12-2004, 09:40 PM
New User
1fstevo's Avatar
not too long ago, I switch back from a .4bar spring to 1.1bar spring. Omg, I never sweat and I was dripping! I had a friend helping me.
Old 04-13-2004, 07:18 AM
blackeg's Avatar
Default Re: Difficulty of changing a tial 38mm wastegate spring? (Evo Hybrid)
i opened mine up the other day to find a 1bar spring . i had a friend hold that **** tight, while i used a wratchet and took off the bolts. once you get down to 1 bolt left- you or your friend needs to hold that **** real tight. with help it took me like 2 minutes, and i was watchin tv at the same time . semi off topic question and sorry if this is a thread jack, is there a specific torque we should use when re-tightening the bolts that hold the wastegate together???
Old 04-13-2004, 09:32 AM
4-banging's Avatar
Default Re: Difficulty of changing a tial 38mm wastegate spring? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">is there a specific torque we should use when re-tightening the bolts that hold the wastegate together???</TD></TR></TABLE>
I'd like to know too. I have a 10psi spring and contemplating whether to downgrade??
Old 04-13-2004, 07:54 PM
PGT Driver's Avatar
ya i have a 10psi spring and want to downgrade as well.
Fastjato33
02-20-2009 10:31 PM
RICE POLICE SIP
09-26-2006 07:24 PM
FlatTire
04-29-2004 01:47 PM
Quick Reply: Difficulty of changing a tial 38mm wastegate spring?
