Diagnosing The Problem...official Update thread........
well first of all, i dont agree with some of the things that 'viperdude' posted.
which lead me to figure out who he was.
Secondly,
92SleepyHB
Stoney
Stoney's My Idol
viperdude
all have the same IP address 4.26.208.215. which may or may not mean anything, i dont know if its work computer, or what ....dont really care at this point.
Next, you are disregarding pretty much proven theory. that car ran way too much timing for 19 psi on pump gas. no way around it. it was probably on the edge of detonation, and as luck has had it, it finally popped.
Im not going to get into theory right now, i could spend all day on it. I have an exam a 3 hours and another one tomorrow.
I think the best thing to do, and im not trying to call anyone bad tuners here, note the number of failures you guys have had, look at the ignition timing you guys are running (way more than other acclaimed tuners) , also note the problems: possible detonation, lifting heads (could be caused by too high cylinder pressures..ie detonation as well).
I run way less ignition timing then you guys run, and i havent had a 400 whp car on pump gas blow yet. i just made 500 whp on pump not too long ago, and i can assure you, i was a hell of a lot less timing than what brian was running. just because you run less timing doenst mean it wont make good power....give it a try. and if you guys arent sure, hit me up, ill help you out.
so i think everyone should just end it, let it be a lesson learned, try running a **** load less of timing, and im willing to bet, there will be a lot less problems...
but your entitled to your own opinions, if you guys think you're doing the right thing, keep at it, u may or may not keep blowing motors, but im telling you what i would do.
Secondly,
92SleepyHB
Stoney
Stoney's My Idol
viperdude
Mase how they all come up with the same ip address is that is our work router's ip. ViperDude came up to the shop just to stop by and posted because of some of the things being said. No we are all not the same person if that is what you were trying to get at or that we all work together. Also 92sleepyhatch is just a customer that comes up there. We let our friends jump on the computer if they want at work cuz one of our computers doesnt get used most of the time.
