DIAGNOSE THIS!!!!!!!!!!!
Old Nov 14, 2008 | 07:37 PM
vtechjunkie's Avatar
Default DIAGNOSE THIS!!!!!!!!!!!
i recently installed a turbo. before all this ther was a small bit of vapor coming from the back of the motor. the tuner told me that it started to slightly miss ;at idle and about 25 hundred rpm, when he was tuning it. he then told me that he could not get it to go away. when installing my o2, he noticed that there was oil all over the lower back end of my motor,half shaft, and axel. he said it was running good for him other than the miss though and that the leak and miss were probably related. i drove home (about 40 miles or so) that night and the miss seamed to get a little worse as i drove it regular more. boosted couple of times. drove fine. leak didnt seam to get worse at all. not much of anything on the cement. the next morning the smoke from the back of the motor didnt seam to be any worse. the miss was. i will add that when installing the turbo, it leaked a little coolant ; while the front was jacked up,from a un-tracable source. due to a brace or something under the firewall area. (i drive an eg coupe with a b16obd1).
A HEAD GASKET? WORSE? ANY HELP APPRECIATED!!!!!!!!!!!!!!!!!!!!!
Old Nov 14, 2008 | 07:49 PM
rota92
Guest
Posts: n/a
Default Re: DIAGNOSE THIS!!!!!!!!!!! (vtechjunkie)
It's usually blinker fluid from the back of the motor, be sure to change it out after buying a new reservoir and be ready for some real power
This thread does nothing without pics, anything that we would tell you to look for that's leaking without more info would be something that you can go see with your own eyes.
Old Nov 14, 2008 | 08:32 PM
Default Re: DIAGNOSE THIS!!!!!!!!!!! (rota92)
what a comedian!
Old Nov 14, 2008 | 09:21 PM
rota92
Guest
Posts: n/a
To answer your PM, we would need pics of the leakage on the motor.
But first off, you need to clean it all up. Then let the car run on jackstands or something so you can watch for it.
It's also good to start off with letting us know what you've tried so far, how old everything is etc.
You can never give too much info, but it's very easy to give little or none at all. You just won't get the result your looking for without some effort on your end.
Old Nov 15, 2008 | 05:51 AM
cool. everything is new as far as bolt ons go. the motor was built last spring. ill get pics and vids soon.
Old Nov 15, 2008 | 05:52 AM
thought i would do some research first. then tear in.
Old Nov 15, 2008 | 11:49 PM
ttt
Old Nov 16, 2008 | 02:58 PM
90blackcrx's Avatar
Could be a number of things, oil pan gasket blowing out, pcv system leaking oil ( we had this with a customers car before ) . Do what Rota said.
Old Nov 16, 2008 | 03:01 PM
marcj's Avatar
Default Re: DIAGNOSE THIS!!!!!!!!!!! (90blackcrx)
AIDS
Old Nov 16, 2008 | 03:02 PM
90blackcrx's Avatar
Default Re: DIAGNOSE THIS!!!!!!!!!!! (marcj)
Originally Posted by marcj
AIDS
Do not wantz
Old Nov 17, 2008 | 05:27 AM
integraturbo's Avatar
if u have a cometic headgasket thats ur problem.
Old Nov 17, 2008 | 08:38 AM
SovXietday's Avatar
There are a million and one reasons why a car will miss, and an oil leak is generally not one of them. Unless that is if you have a shaft seal leak in the dist or you're getting oil down the spark plug tubes etc etc etc.
I'd start by pulling plugs, making sure they're not fouled out. Check cap/rotor, check spark plug wires to make sure they're not arcing. You know, the basics.
Old Nov 17, 2008 | 08:39 AM
SovXietday's Avatar
Old Nov 17, 2008 | 08:44 AM
SovXietday's Avatar
shawty22
Aug 13, 2011 02:52 PM
Mattb16teg
Nov 13, 2010 06:19 PM
WhoGunz517
Sep 16, 2010 08:42 PM
SpoolnByYou
Jan 13, 2006 08:03 AM
johnisenglish
Jan 9, 2003 09:32 PM
