Det Cans
Old Mar 15, 2006 | 09:46 AM
  #76
See Are X's Avatar
Default Re: (boosted94cx)
I just finished making mine last night, only costed me $24. I used air compressor hose, anyone think thats too soft? I'll try it out when I figure out where im going to mount this thing.
Old Mar 15, 2006 | 11:28 AM
  #77
SOHC_MShue's Avatar
Default Re: (See Are X)
That will probably be fine. Let us know how it works
Old Mar 15, 2006 | 02:29 PM
  #78
See Are X's Avatar
wow! this thing really works! I've been detonating all this time, right around 6000-7000rpm, this is my area of peak fuel consumption too.
SOHC_MShue, how did you route the hose through the firewall? I had mine coming out of the back of the hood and through the driver side window. The problem I had with this is the hood was pinching the hose.
Old Mar 15, 2006 | 05:55 PM
  #79
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">wow! this thing really works! I've been detonating all this time, right around 6000-7000rpm, this is my area of peak fuel consumption too.
SOHC_MShue, how did you route the hose through the firewall? I had mine coming out of the back of the hood and through the driver side window. The problem I had with this is the hood was pinching the hose.</TD></TR></TABLE>
I ran mine through a hole in the firewall. I believe it was where cruise control went. How much timing are you running in that area? I found that I had been detonating all this time as well with 1deg/psi of timing pulled out and 11.5:1 afr's! I actually no joke had to pull about 5* after vtec crossover to keep it from pinging. I'd like to see other people try this out and see if they are picking up light detonation
Old Mar 15, 2006 | 05:59 PM
  #80
ccivic's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Dave Blundell is a very very very good person to spend a day with, as well. </TD></TR></TABLE>
Tell me about it.. every time I talk to him (pretty frequently), I get a new perspective on everything that I was considering. Dave's a VERY theory based guy, and can explain how everything works, and why it works. I've never heard someone talk sooo technically about water injection (over a 2am dinner a waffle house haha).. he really thinks EVERYTHING through.
Old Mar 15, 2006 | 06:11 PM
  #81
Flr Power's Avatar
Default Re: (ccivic)
It seems allot of guys will find they have been using too much timing.
This is going to impact the aftermarket pistons company since less people are going to blow their engines.
Old Mar 15, 2006 | 07:43 PM
  #82
See Are X's Avatar
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
I ran mine through a hole in the firewall. I believe it was where cruise control went. How much timing are you running in that area? I found that I had been detonating all this time as well with 1deg/psi of timing pulled out and 11.5:1 afr's! I actually no joke had to pull about 5* after vtec crossover to keep it from pinging. I'd like to see other people try this out and see if they are picking up light detonation </TD></TR></TABLE>
i'm running 20* in this area with 11.5 afr's. I'll probably retune it again tomorrow. I'll probably run timing numbers like these...
5k-6k rpm - 19*
6k-7k rpm - 17*
7k-8k rpm - 19-20*
...but i'll let you know what the final numbers are.
Old Mar 15, 2006 | 08:27 PM
  #83
Joseph Davis's Avatar
Soft walled hose is going to, at some level and to some extent, dampen vibrations/sound. But, since you guys seem to be hearing things pretty well, it's probably not significant. I'd just recommend varying hose lengths to see if sound properties change noticeably, try to get a feel for the system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">wow! this thing really works! I've been detonating all this time, right around 6000-7000rpm, this is my area of peak fuel consumption too.</TD></TR></TABLE>
Fuel follows torque, and peak torque is where peak cylinder filling and combustion pressure occurs... it is also where detonation is most likely to happen. Your AFRs look good, and your idea of drawing out a few degrees fo timing where det occurs is solid. Frankly, if the det is really pronounced, you can pull more than 2-3 degrees without losing significant power..
6-7K peak torque, eh? IM me your setup, please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard someone talk sooo technically about water injection (over a 2am dinner a waffle house haha).. he really thinks EVERYTHING through.</TD></TR></TABLE>
Yeah, that's one of our favorite conversations. That, and manifold dynamics (30 minutes ago). And alcohol. And women. Did I mention that he came down for the weekend a month and a half ago, and within 15 minutes of meeting my (female) roomate he almost had his dick in her? The boy is a pimp and a scholar!
Old Mar 15, 2006 | 08:29 PM
  #84
SOHC_MShue's Avatar
Yea man let me know. Just to let you guys know exactly how conservative my timing needed to be to make the pinging go away completely....i am running about 12* total timing at 12psi. I had to pull the most timing out around vtec crossover though. I suspect it could possibly have something to do with the location of my iat sensor in the charge pipe rather than in the intake manifold. This causes it to read much lower temps than the obd1 ecu code is used to seeing so i'm guessing that could be doing something with the timing. I would think it would retard timing though due to having a denser charge so who knows.
Old Mar 15, 2006 | 08:58 PM
  #85
You seen Crome's new setup, where you can manipulate fuel and ignition based on IAT?
Old Mar 15, 2006 | 10:21 PM
  #86
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">You seen Crome's new setup, where you can manipulate fuel and ignition based on IAT?</TD></TR></TABLE>
Yea i've seen it. I've been meaning to tune my car on crome, but right now its running uberdata. Between classes and tuning other cars I have no time to tune my own car espescially since it takes forever with me swerving all over the road and trying to adjust values on the computer while driving . I have cromepro though so I really need to throw down a quick tune and check to see what the actual timing output is with datalogs.
Old Mar 15, 2006 | 10:26 PM
  #87
I Have an STD's Avatar
wrenchin'
wow, this thread is amazing, the start of something that seems really big, im in it to LURK!!
Old Mar 16, 2006 | 04:32 AM
  #88
See Are X's Avatar
here's a dyno graph of my street tune...this is with my timing completely untouched, just on a step-retard. I have advanced my timing a lot since. If I ever get tune my car on a dyno I could probably get peak torque to come in a little earlier.
Setup:
t3/to4e 63ar .57trim
revhard turbo manifold
aebs intake manifold
2.5inch downpipe
2.25inch exhaust w/ no muffler
Old Mar 16, 2006 | 01:23 PM
  #89
coneheadsracing's Avatar
curse this michigan weather, anyone get a chance to try it wiht a computer yet? I can't wait to get out and try this out.
Old Mar 16, 2006 | 03:49 PM
  #90
See Are X's Avatar
Default Re: (coneheadsracing)
I finally got a chance to try the det can out...its a stock block b16 on 9psi(3rd line up from the bottom)
...I went from this...
...to this...
...im probably going to need to retard it even more from 7500rpm up, I still hear a little detonation there.
Modified by See Are X at 3:17 AM 3/17/2006
Old Mar 16, 2006 | 06:40 PM
  #91
SOHC_MShue's Avatar
holy **** looks like you had to pull about as much as me.
Old Mar 16, 2006 | 08:19 PM
  #92
Crazy, you're still making good torque at 7K. Was there any boost creep to speak of during that dyno pull?
Old Mar 17, 2006 | 08:01 AM
  #93
SOHC_MShue's Avatar
so anyone know of a good spot to hook one of these up on a b series block with power steering?
Old Mar 17, 2006 | 08:03 AM
  #94
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">so anyone know of a good spot to hook one of these up on a b series block with power steering?</TD></TR></TABLE>
Lol the anti-lazy, go try!
Old Mar 17, 2006 | 11:27 AM
  #95
SOHC_MShue's Avatar
Default Re: (Si Shane)
Yea i'm thinking I can pretty much hook it anywhere on the engine because even with mine put on the block where it is now I can still hear the bov and noise from my broken tranny pretty well.
Old Mar 17, 2006 | 08:40 PM
  #96
SOHC_MShue's Avatar
bump it up. I wanna see other people testing this stuff
Old Mar 17, 2006 | 11:23 PM
  #97
raene's Avatar
Well I tried it. About $20 CDN in parts so far into it and I have enough hose and tubing to make another one. I gotta say, it works GREAT. I just need some way to hook it up to the ears 'cause driving a manual, shifting, and holding a tube in your ear just isn't easy.
from me!
Old Mar 18, 2006 | 12:04 AM
  #98
SOHC_MShue's Avatar
Default Re: (raene)
bwahahaha i tuned by holding the tube to my ear at first too before i got the headphones all hooked up
Old Mar 18, 2006 | 07:25 AM
  #99
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">bwahahaha i tuned by holding the tube to my ear at first too before i got the headphones all hooked up </TD></TR></TABLE>
We've gotta hook one up on my new D15
Old Mar 18, 2006 | 08:32 AM
  #100
SOHC_MShue's Avatar
Default Re: (JDMs1eeper)
hahahaha I knew you would try to turbo that thing
