Det Cans
Old Mar 13, 2006 | 08:26 AM
  #51
SOHC_MShue's Avatar
Default Re: (J. Davis)
Thanx for the info J. Davis! I am pretty interested in trying to make an electronic knock detection thing like you made. I just need something that is small and can easily be used on other cars I tune. Obviously my det cans are probably to big unless I made different size pipes for different engines and stuff.
Old Mar 13, 2006 | 09:27 AM
  #52
See Are X's Avatar
I gotta try this...where could I buy some ear muffs/protectors?
Old Mar 13, 2006 | 09:51 AM
  #53
MindEracer's Avatar
Default Re: (See Are X)
Oops..
Old Mar 13, 2006 | 09:52 AM
  #54
MindEracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Dave Blundell is a very very very good person to spend a day with, as well. </TD></TR></TABLE>
I bet, I've learned so much just from the online conversations we've had.
I' m going to home depot now, need to give this a try. What kind of earphones/protectors did you use SOHC_MShue?
Modified by MindEracer at 1:36 PM 3/13/2006
Old Mar 13, 2006 | 09:54 AM
  #55
splitime's Avatar
Default Re: (MindEracer)
As you guys go the one route, I'm going to try and make one of the electronic ones that J.Davis has been talking about. I'll do my best to put together a DIY write-up for it.
Old Mar 13, 2006 | 10:13 AM
  #56
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer &raquo;</TD></TR><TR><TD CLASS="quote">I bet, I've learned so much just from the online conversations we've had.
I' m going to home depot now, need to give this a try. What kind of earpones did you use SOHC_MShue?</TD></TR></TABLE>
I just used some generic ear protectors my dad had lying around that he used when mowing the lawn . You can get them at lowes or something i'm sure. In fact everything I used came from lowes except for those which i got for free.
Old Mar 13, 2006 | 10:59 AM
  #57
Si Shane's Avatar
Default Re: (SOHC_MShue)
From what I've heard, the difference between a human ear using a knock sensor and these cans is what JD alluded to. The Knock Sensor is not actual, un-transduced, viabrations coming to your ear, whereas the cans are.
Old Mar 13, 2006 | 11:21 AM
  #58
Joseph Davis's Avatar
BigMoose's Ramblings, the right hand column has the knock sensor stuffs.
This is the page on recording knock sensor sounds, and graphical representation of the audio information.
I don't mean to post this stuff up to sidetrack from det cans, in fact if you can record det can output and render it graphically a la the second link above, we might end up ahead of the game.
However, if you want to approach the matter from an electronics standpoint, VEMS has some good info you can explore on here for perusal. It also has some great detonation info, for general knowledge.
Old Mar 13, 2006 | 11:42 AM
  #59
MindEracer's Avatar
Here is another link to look on how to make an electronic detector:http://autospeed.drive.com.au/....html
And another on how to make a detonation recorder:http://autospeed.drive.com.au/....html
I don't mean to get off track from the "Det Can" discussion, but this may help with the info Jdavis posted..
PS:I did find some ear protectors at home depot fo $10
Old Mar 13, 2006 | 11:45 AM
  #60
autospeed rules!
I'm posting this shizzle up with the intent to get some of you guys to take audio recordings of your det cans, and the rest for the sake of general knowledge.
Old Mar 13, 2006 | 11:49 AM
  #61
MindEracer's Avatar
Hmm.. I need a mic..Can probably just record right onto my laptop..
Old Mar 13, 2006 | 11:51 AM
  #62
coneheadsracing's Avatar
I haven't tried this yet... liking all the ideas though, but i have one too.
I was thinking that you take the first guys idea, copper pipe and some tubing, run that into a small box, probably with foam inside, maybe somehting else. Then you know those microphones that you use with your computer, what if you stuck that inside the box, then plugged that into your computer. Then you would just need some sort of program to see the audio waves, (any suggestions). You could also use your laptop to a.) listen and b.) watch all while running the tunning program of your choice. If someone has a program that would work with this, i'm up for making one.
Old Mar 13, 2006 | 11:56 AM
  #63
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">autospeed rules!</TD></TR></TABLE>
Having partial access to autospeed makes me cry
Old Mar 13, 2006 | 12:34 PM
  #64
MindEracer's Avatar
Default Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote"> haven't tried this yet... liking all the ideas though, but i have one too.
I was thinking that you take the first guys idea, copper pipe and some tubing, run that into a small box, probably with foam inside, maybe somehting else. Then you know those microphones that you use with your computer, what if you stuck that inside the box, then plugged that into your computer. Then you would just need some sort of program to see the audio waves, (any suggestions). You could also use your laptop to a.) listen and b.) watch all while running the tunning program of your choice. If someone has a program that would work with this, i'm up for making one. </TD></TR></TABLE>
That is exactly what i was thinking..
U would have an mp3/wav etc. file to share and analize..
Modified by MindEracer at 4:42 PM 3/13/2006
Old Mar 13, 2006 | 01:57 PM
  #65
evilone's Avatar
found that the TXS tuner box works well if you have some ambient noise reducing headphones http://www.bose.com/controller...15318
can get a bit costly though
Old Mar 13, 2006 | 03:48 PM
  #66
boosted94cx's Avatar
* B A N N E D *
and he lets you play with flare guns!
&lt;--misses being jobless and being able to romp around the country, care free
Old Mar 13, 2006 | 03:55 PM
  #67
.nate's Avatar
I'm thinking a microphone would be easily incorporated into the det can setup, as long as RF interference can be avoided. Then we would be able to pump the output to a set of headphones and or a laptop for analysis.
Old Mar 13, 2006 | 06:26 PM
  #68
Default Re: (.nate)
anyone have an analyzer program. I found free ones, but they are all just plugins, and i don't have a main program. Whats a good share program nowadays, havne't used one in a long time. I'd like to try this by this weekend, but michigan is thinking winter should return, so we shall see.
Old Mar 13, 2006 | 08:19 PM
  #69
Default Re: (boosted94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">and he lets you play with flare guns!</TD></TR></TABLE>
Oh god, he let you play with a flare gun? I knew he hated you, I think he was hoping you'd put out an eye.
Old Mar 14, 2006 | 07:36 AM
  #70
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Oh god, he let you play with a flare gun? I knew he hated you, I think he was hoping you'd put out an eye.</TD></TR></TABLE>
yeah...you were inside with atlee and the rest...and we walked down to the feild out behind the shop and shot some flares....i was kinda waiting for the swat team to show up and take you to jail...that way you and blake could be together forever (after the dog incident leaked...he must be in jail by now)
Old Mar 14, 2006 | 10:34 AM
  #71
Chris22215's Avatar
nice information.
*heads to home depot*
Old Mar 14, 2006 | 04:03 PM
  #72
xenocron's Avatar
Default Re: (Chris22215)
What a bunch of hackers
Old Mar 14, 2006 | 04:07 PM
  #73
* B A N N E D *
Default Re: (xenocron)
you're a hacker
Old Mar 14, 2006 | 06:08 PM
  #74
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">you're a hacker</TD></TR></TABLE>
Yeah, you are only the 4th person to call me that today
Old Mar 14, 2006 | 06:15 PM
  #75
* B A N N E D *
you're the 4th person today
