Det Cans
Old Mar 18, 2006 | 08:34 AM
  #101
Bailhatch's Avatar
Default Re: (JDMs1eeper)
So have any of you used both the cans an an electronic listening device? I find the ignition whine is a little distracting on an engine ear. It seems a bit less with a knock sensor but it would be pretty cool to not have it at all.
Maybe I'll build a set of these and tune my recent viper project with them instead of the engine ear...its on race gas and has modified combustion chambers so im not sure where I can go with the timing since I usually tune stock ones.
Old Mar 18, 2006 | 09:24 AM
  #102
SOHC_MShue's Avatar
Default Re: (Bailhatch)
Yea man give it a try and let us know which you like better
Old Mar 18, 2006 | 09:31 AM
  #103
Bailhatch's Avatar
Default Re: (SOHC_MShue)
I think I will. The more I think about it the more I like the Can idea. I'll try my chassis ear back to back with the cans. Im just not sure where I can bolt the cans to. There are some nice spots to clamp the chassis ear to, right at the top of the cylinders, but no bolts.
Old Mar 18, 2006 | 10:08 AM
  #104
SOHC_MShue's Avatar
Yea thats the problem . I've been having trouble finding a good place to bolt this on the b series blocks. You can bolt it near the #1 cylinder if they dont have power steering, but thats about all I see thats easily accessable.
Old Mar 18, 2006 | 10:18 AM
  #105
Bailhatch's Avatar
I think im going to weld a 6" piece of pipe to a small pair of vicegrips so I can clamp it onto the same exact spot as the chassis ear. I'll probably weld the pipe right to the upper jaw on the vice grips so its as direct as possible.
I probably wont use any fitting though, just slide some air hose over it and use hose clamps
Old Mar 18, 2006 | 01:56 PM
  #106
SOHC_MShue's Avatar
Good idea.
Old Mar 20, 2006 | 05:01 AM
  #107
mrx's Avatar
mrx
Default Re: (See Are X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">...I went from this...
...to this...
...im probably going to need to retard it even more from 7500rpm up, I still hear a little detonation there.
Modified by See Are X at 3:17 AM 3/17/2006</TD></TR></TABLE>
Are you sure you have detionations?
i drive my stock b16a1 10.2:1 CR with 8psi and have 21,96° after 7krpm and have no problems at all...
Old Mar 20, 2006 | 06:16 AM
  #108
SOHC_MShue's Avatar
Default Re: (mrx)
I basically had to do a similar thing with my sohc timing maps. I tuned another sohc with the det cans though that wanted a more normal amount of timing so i think my car just sucks
Old Mar 20, 2006 | 07:24 AM
  #109
cobra2326's Avatar
This is good ****. Im going to try it out on my b16, maybe this weekend.
Old Mar 20, 2006 | 07:30 AM
  #110
See Are X's Avatar
Default Re: (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you have detionations?
i drive my stock b16a1 10.2:1 CR with 8psi and have 21,96° after 7krpm and have no problems at all...</TD></TR></TABLE>
you should make one of these det cans, you'd probably be surprised. Unless the, rice falling on foil, sound i'm hearing is normal then I might be wrong. But I was able to eliminate that sound by taking out timing, so I dont know what else it could be.
The only way I can think of that will kind of tell us if this thing works right, is to test the det can on a engine with the timing properly tuned on a dyno. And see what kind of sounds the det can picks up.
Old Mar 20, 2006 | 07:38 AM
  #111
VTC_CiViC's Avatar
Looks like I'll be hitting Home Depot today.....
Old Mar 20, 2006 | 07:39 AM
  #112
SOHC_MShue's Avatar
Yea our problem is strange. I've been trying to figure out the cause of it. One thing I thought of is maybe my ecu is running more timing due to my iat sensor being in the intake pipe and reading much lower than normal iat's. I would think it would actually run less timing though. Also I am running a y8 obd2 dizzy on my z6 head. Even though the timing and everything seems synced up I dont know what it is doing under load.
Old Mar 20, 2006 | 07:48 AM
  #113
cobra2326's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">you should make one of these det cans, you'd probably be surprised. Unless the, rice falling on foil, sound i'm hearing is normal then I might be wrong. But I was able to eliminate that sound by taking out timing, so I dont know what else it could be.
The only way I can think of that will kind of tell us if this thing works right, is to test the det can on a engine with the timing properly tuned on a dyno. And see what kind of sounds the det can picks up.</TD></TR></TABLE>
Why not pull the plugs when you get this sound and double check?
Old Mar 20, 2006 | 08:44 AM
  #114
raene's Avatar
Default Re: (mrx)
I cracked my #3 ringland running that much timing on 94 octane on 7psi... for sure I had detonation with a similar setup
I actually made MORE power at 18 degrees total... on the new bottom end of course
Old Mar 20, 2006 | 09:05 AM
  #115
mrx's Avatar
mrx
Default Re: (raene)
Hallo Raene,
interesting... maybe i should check that... :-) but last time i checked the plugs during tuning session i don't have any detionations
Old Mar 20, 2006 | 09:12 AM
  #116
See Are X's Avatar
Default Re: (cobra2326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 &raquo;</TD></TR><TR><TD CLASS="quote">Why not pull the plugs when you get this sound and double check? </TD></TR></TABLE>
I have checked my plugs. Even with the timing map ive been using(before I made the det can)I did not see any signs of detonation. I heard it, but did not see anything on the plugs.
Old Mar 20, 2006 | 09:24 AM
  #117
SOHC_MShue's Avatar
I have found it hard to distinguish between what is and what isnt detonation on the plugs. I think to really see slight detonation on the plugs you need to look very closely...maybe even use a magnifier.
Old Mar 20, 2006 | 09:31 AM
  #118
mrx's Avatar
mrx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I have found it hard to distinguish between what is and what isnt detonation on the plugs. I think to really see slight detonation on the plugs you need to look very closely...maybe even use a magnifier. </TD></TR></TABLE>
yes, thats true... especialy to see the difference between carbon desposits and knock is not very easy in my eyes...
but when listening with the det can, how do you know the noise is knock... a Vtec engine like the b16 or b18 makes a lot of noise from the valvetrain especialy when in vtec...
i don't have a exact feeling but when you get knock by ~20° on a 10:1 CR engine, the tuning width is very very small to make MBTT, i would say without racefuel its impossible to reach MBTT with such an engine. or what do you guys think?
i will try to lower my 20° to 16,9° (maximum timing @ around +7k) and see if the noises of my engine will change.
Old Mar 20, 2006 | 10:02 AM
  #119
Si Shane's Avatar
If you are not using a 10x magnifying glass you are not reading the plugs.
Old Mar 20, 2006 | 10:15 AM
  #120
SOHC_MShue's Avatar
Default Re: (mrx)
i will try to lower my 20° to 16,9° (maximum timing @ around +7k) and see if the noises of my engine will change.</TD></TR></TABLE>
I have heard audible detonation before and this sounds the exact same. I would say the same thing as you that this could possibly just be valvetrain noise, but if it goes away with pulling out timing then you know it is more than likely knock.
Old Mar 20, 2006 | 10:18 AM
  #121
mrx's Avatar
mrx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I have heard audible detonation before and this sounds the exact same. I would say the same thing as you that this could possibly just be valvetrain noise, but if it goes away with pulling out timing then you know it is more than likely knock. </TD></TR></TABLE>
yes, then you are right... if it goes away with changing timing then it is def. no valvetrain noise... :-)
i have burned a chip and when driving to work tomorrow i will check it if something changes and then report
Old Mar 20, 2006 | 10:39 AM
  #122
VTC_CiViC's Avatar
Default Re: (mrx)
i don't have a exact feeling but when you get knock by ~20° on a 10:1 CR engine, the tuning width is very very small to make MBTT, i would say without racefuel its impossible to reach MBTT with such an engine. or what do you guys think?</TD></TR></TABLE>
I've reached MBT on 10:1 engine on 93 octane, but this was with pulling the plugs at a number of points on the way to 8k, so now I wonder if there has been some minor knocking not showing on the plugs
Although I typically only see about ~17-18* of advance on B18C's @ 9-10psi, ~16* on B16's while making within a few ft-lbs of best torque anyways. *shrug*
Old Mar 20, 2006 | 11:10 AM
  #123
cobra2326's Avatar
Default Re: (VTC_CiViC)
Heres my low cam map on my JDM b16. I had to pull a lot of timing right when peak boost hits in order for my plugs to NOT show knock.
Old Mar 20, 2006 | 12:33 PM
  #124
JDMs1eeper's Avatar
matt, lets boost this d15
Old Mar 20, 2006 | 02:40 PM
  #125
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">matt, lets boost this d15 </TD></TR></TABLE>
I think you need to build another 10 second car and quite beating around the bush.
