Darton MID sleeves - Necessary to O-ring block??
Old Jun 3, 2004 | 05:28 PM
dunkd's Avatar
Default Darton MID sleeves - Necessary to O-ring block??
I was told by someone that with the new Darton MID sleeve kit you must O-ring the block to maintain stable pressures within each cylinder - it wont hold past 15psi.... is this true?
Old Jun 3, 2004 | 06:24 PM
DaveF's Avatar
Default Re: Darton MID sleeves - Necessary to O-ring block?? (dunkd)
does the block have the grooves cut in the sleeves for the o-rings?
maybe a cometic hp gasket would be a good choice, if you didnt want o rings? <--someone wanna comment on this ????
Old Jun 3, 2004 | 06:58 PM
dunkd's Avatar
already plan on using OEM headgasket bored out to 84mm by golden eagle. no grooves tho...
Old Jun 3, 2004 | 07:52 PM
BodyKits NW's Avatar
Default Re: (dunkd)
I don't believe it is true.
Old Jun 3, 2004 | 08:50 PM
Dr Pooface's Avatar
Default Re: (BodyKits NW)
Phone Darton.
Old Jun 3, 2004 | 09:00 PM
m R g S r's Avatar
Default Re: (Dr Pooface)
Is it just me, or are those holes in the coolant jacket area un evenly drilled? Is there a purpose of that?
Old Jun 3, 2004 | 09:14 PM
lonnieboost's Avatar
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Is it just me, or are those holes in the coolant jacket area un evenly drilled? Is there a purpose of that?</TD></TR></TABLE>
Yes they are, I think its for the gasket to line up with the holes
Old Jun 4, 2004 | 01:18 PM
Sinitron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">I was told by someone that with the new Darton MID sleeve kit you must O-ring the block to maintain stable pressures within each cylinder - it wont hold past 15psi.... is this true?
No.
Their design only changed the placement + depth of the sleeves, doesn't matter if you have them cut o-ring grooves in or not, its just an option.
Daron prokits will hold enough boost that stock size headstuds will lift off the block before you have to o-ring.
Old Jun 4, 2004 | 01:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Darton MID sleeves - Necessary to O-ring block?? (Sinitron)
o-ringing is a good step , i had my y8 block o-ringed.... a cometic fire ring gasket will do the same thing im sure . but ive never herd of "having" to o-ring a block for any reason.
why did you get mid sleeves anyway , why are they different? did you crack a sleeve or somthing?
Old Jun 4, 2004 | 06:36 PM
dunkd's Avatar
the MID sleeves are just Dartons newest line of sleeves... different design than the older ones.
sleeved block bc that makes it stronger
Old Jun 4, 2004 | 09:02 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (dunkd)
ive always heard that "mid" sleeves were for cracked stock sleeves...no ******* **** they are to make the block stronger
Old Jun 4, 2004 | 09:12 PM
dunkd's Avatar
modular intergrated deck
i dont quite understand what you are saying. if a sleeve is cracked then it is pressed out and a new sleeve is pressed in. what kind of sleeve that is pressed back in is 100% by preference...
Old Jun 7, 2004 | 05:46 PM
dunkd's Avatar
any other input?
Old Jun 8, 2004 | 12:19 PM
Sinitron's Avatar
Default Re: (dunkd)
Its not as simple as just pressing out an old sleeve, and popping in new ones.
They cut the webbing and under the deck area to bind the whole block together with their interlocking sleeves.
Call Darton and request their solid deck install literature (its a big folder w/ pictures), it shows you and explains the install process. Bottom line tho, you dont need o-rings w/ their system.
Old Jun 8, 2004 | 12:33 PM
PM-Performance's Avatar
Default Re: (Sinitron)
Mine was Oringed and was fine, as well as the one above is my friends and is fine . I dont think you have the option to Oring Dartons, But they seal fine. I used a Cometic HP on mine and the one above is using a stock HG and both seal fine
Old Jun 8, 2004 | 01:37 PM
93LSivic's Avatar
Default Re: (itr206)
No need for o-ringing. I actually dont even recommend it at all. What I do recommend is that you use the Cometic HP gasket, the one with the "fire ring".
Old Jun 8, 2004 | 05:07 PM
earl's Avatar
Default Re: (93LSivic)
O-ringing or stepping the deck will give you the same effect...it just pushes into the head gasket a little harder to help seal. Just remember you can't use the Cometic HP gaskets with a step or o-ring. Use the MLS in that case.
kornerk12
Jun 4, 2007 05:44 PM
RYan McG.
Nov 29, 2006 09:48 AM
b16nonoy
May 15, 2006 05:13 PM
dunkd
Aug 31, 2004 09:00 AM
GreddySi99
Oct 15, 2003 09:35 AM
