Precision 1000cc injectors (what do they look like?)
mine look exactly like that..
I thought those were Delphi Rochestor Injectors..
am i wrong? or was i sent the wrong thing?
Re: Precision 1000cc injectors (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">i have pte 880cc and they look the same, you have to get the numbers off them and that will tell you what they are.</TD></TR></TABLE>
what do the numbers mean also? they dont exactly say 1000cc or XX.lbs
Re: Precision 1000cc injectors (Jordo)
when you look at the injector from the top it will be the longer set of numbers they should be the same on all injectors, then just search or ask viren he knows all the numbers and specs.
Re: Precision 1000cc injectors (Arturbo)
I know this is old, but i got a question. What do the 880cc look like. I just need to know if they say "precision" on them or not?
Re: Precision 1000cc injectors (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 »</TD></TR><TR><TD CLASS="quote">I know this is old, but i got a question. What do the 880cc look like. I just need to know if they say "precision" on them or not?</TD></TR></TABLE>
No they don't.
No they don't.
Re: (RNPoo7)
the numbers on the injector are the flow rating and the manufacture date it was flowed the number on the top of the injector is the actual rochester part number which can be refereced for any multec injector ..
the only difference between the rochestor cores and the precision is that preicison uses a lathe to cut the top of the injector to fit into our given rail. The actual clips use obd 0 style clips.
For obd 1 you will need to cut a tab inthe injector theres a protruting tab that needs to be removed.
for obd 2 you know what to do.
