Benefit of a block gaurd
Old Nov 29, 2006 | 07:39 AM
RYan McG.'s Avatar
Default Benefit of a block gaurd
What is the benefit of a block guard? and is it really worth spending the $$$?
Old Nov 29, 2006 | 07:42 AM
BoostedEG6's Avatar
Default Re: Benefit of a block gaurd (RYan McG.)
no.... the proper way to use one would to be to have it installed and then have it bored/honed to make sure that everything is inline and rounded
Old Nov 29, 2006 | 09:01 AM
b18sihatch's Avatar
Default Re: Benefit of a block gaurd (BoostedEG6)
x2 and i would also have it decked depending on how deep they sit, i got sleeves and no nothing about the block guards expect they arent a replacement for sleeces and dont really help the structural integrity of the cylinder sleeves, as the sleeves are still aluninum and not ductile iron like aftermarket sleeves
Old Nov 29, 2006 | 09:16 AM
slow poke's Avatar
Simple Answer... None
DONT wast your money!
Old Nov 29, 2006 | 09:18 AM
SovXietday's Avatar
Default Re: Benefit of a block gaurd (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">x2 and i would also have it decked depending on how deep they sit, i got sleeves and no nothing about the block guards expect they arent a replacement for sleeces and dont really help the structural integrity of the cylinder sleeves, as the sleeves are still aluninum and not ductile iron like aftermarket sleeves</TD></TR></TABLE>
They're designed to keep the sleeves from shifting, but often times starve certain areas of the sleeves of coolant causing hot spots and other issues.
Some people swear by them, others will never use them. If you put it in, make sure it's done right.
Old Nov 29, 2006 | 09:48 AM
I.C.C.'s Avatar
I had mine professionally installed by a local machine shop, and have had no issues with it whatsoever.... They basically press it in with the same machine used to press in sleeves, deck the block, bore and hone the block and thats it... The block is still in my car daily driven making almost 600whp and beat on, on a regular basis... No issues at all...
kornerk12
Jun 4, 2007 05:44 PM
b16nonoy
May 15, 2006 05:13 PM
FormulaGSR
Feb 27, 2005 10:30 AM
GreddySi99
Oct 15, 2003 09:35 AM
turbodGSR
Apr 27, 2003 09:00 AM
