D16 Turbo....what oil pump to run.
I need to know if I should run a higher flow, aftermarket oil pump or an OEM one will be sufficient in my D16Z6. I am looking for 325-400hp. Built, T3 Super 60 powered.
Thanks.
Thanks.
Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">youi wont be making near that power with a super 60
use OEM pump</TD></TR></TABLE>
.72 intake trim, and .63 on the exhaust side, whatever turbo that is.
Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">it get a 50 trim with .63 a/r</TD></TR></TABLE>
Re: (Timmay)
Ok. Have all new water pump, t-belt, and alt belt. Will get a new oil pump coming.
Going Neptune.
Anything else I should have to worry about?
Going Neptune.
Re: D16 Turbo....what oil pump to run. (ExcessivePerformance)
it's not the power the pump cant handle it's the rev's
how high are you giong to reve the motor
the stock d16 pumps have problems over 8500 or so..
something to do with the way it spins. you can bore out the oil passage for a little bit more....
platinum..
platinum..
Re: D16 Turbo....what oil pump to run. (RyanCivic2000)
When inspecting your oil pump make sure its within specs when you build
Inner to outter rotor clearance
.001-.006
Rotor to pump body radial clearance
.004-.007
Rotor to pump body side clearance
.001-.003
Stock oil pump here!
.001-.006
.004-.007
.001-.003
