2k Stg2 almost Flat lines..
Old May 24, 2006 | 06:38 PM
JFG Kevin's Avatar
Default 2k Stg2 almost Flat lines..
Just wondering if anyone else has this problem. I have GSR motor with CTR piston and stg 2 cams. Vtec is set to engage at 6grand, but when vtec does engage, it almost flat likes for about 500 rev...Sorry no Graph, can't find it no more...but just wondering does anyone have the same problem...
Modified by aznstyler119 at 9:54 AM 5/26/2006
Old May 25, 2006 | 02:15 PM
devnull's Avatar
Ignition is too high or low and/or you are too rich. I had a problem with my ignition value being too high and being WAYYYYYY to rich causing the same thing.
Old May 26, 2006 | 12:53 AM
JFG Kevin's Avatar
Default Re: (devnull)
wouldn't my tuning correct that?
Old May 26, 2006 | 08:27 AM
devnull's Avatar
Not if you started with a bad base map and you got a tuner who wasn't "competely" compitant. I know that when I was tuning the guy that was doing mine never touche the igntion until the shop owner came out and was looking at the base map and told him the ignition values above vtec where way to high and then he droped them down alot. If you want i can email you my rom and see if it helps.
Coutts
Engine Management and Tuning
Jul 16, 2010 12:36 AM
boostedeghatch
10
Jan 24, 2009 04:21 AM
bOOsTiNSoHcVtEc
Sep 15, 2005 03:00 PM
DOHCarp
Apr 21, 2005 08:46 AM
DOHCarp
Dec 6, 2004 12:28 PM
