CSS Block/BWs366/Q16-LsVtec Build
Old Oct 16, 2013 | 07:52 PM
  #101
got-vtec?'s Avatar
Default Re: CSS Block/BWs366/Q16-LsVtec Build
Its a much cheaper alternative than buying a billet case for people making a good chunk of power. It helps prevent the trans case from parting/cracking.
Old Oct 16, 2013 | 07:58 PM
  #102
Turbo-LS's Avatar
Im surprised no one makes a billet outter case
Old Oct 16, 2013 | 08:09 PM
  #103
got-vtec?'s Avatar
I thought they did? Maybe the weak link is just the inner side?
Old Oct 17, 2013 | 12:31 AM
  #104
wantboost's Avatar
Who is Mr Robot?
No billet outer for a stock based trans. Most of the forces go through the innerncase "bellhousing" for you other folk lol
the strain of the clutch assembly/power on the input shaft plus the force of the throwout bearing, etc. A lot of the twisting forces center on that inner case. Especially on hard launches, strainful drivetrain conditions (wheelhop, control arm movement, rev matching downshifts repeatedly on road course, then back to full throttle, etc.) If a component were to give it would be the inner trans case (and it has) Not to mention if a clutch component were to fail, the billet case has more "give" or stretch, so the likely hood of a catastrophic shrapnel throwing event is reduced, even more so if using a scatter shield as well.
SiRCiviC94
Jan 5, 2013 01:42 PM
trigger_time
Nov 2, 2010 10:03 AM
Running925
Jul 16, 2007 03:25 PM
ghostrider dc2
Oct 29, 2006 03:00 PM
self_made
Nov 20, 2002 08:35 AM
