CROME tuning and nitrous
I have a pretty complex problem and was wondering if you could help me out. My car was street tuned all motor with CROME and we got my afr to about 14.3-14.3 throughout the rpm band; we only messed with the fuel map and didn't touch ignition timing.
Shortly after, I bought a single solenoid dry kit by NOS with a 0.042 jet. I also got NGK 7 plugs, B&M fpr (set at 45 psi with hose off), and pulled timing by 1 degree. So I hooked up a wideband to it and it runs incredibly rich but has a few lean spots at partial throttle.
When we sprayed at WOT we saw the afr got as high as 35:1 which got me worried, is this too lean for the motor? How can I tune for nitrous? I was planning on tuning for WOT while spraying but does this mean my car will run rich at WOT while not spraying? Thanks for the help.
Re: (turbolshatch)
Try reconnecting the fpr.Dry nitrous still come with something to give it more fuel and disconnect the hose that goes to the nitrous solinoed.That should give u an ideal of were ur at.
Re: (Ray-mond)
You sure you didnt have a leak around or near where the WB o2 was placed?
At 35:1 AFRs your car wouldnt be running, and if it was, it would be misfiring like a SOB
i dunno maybe this is completely retarded and my late night thinking....if he is running a dry system w/ no fuel enrichment...could he actaully be blowing some remenant nitrous into the exh causing the wbo2 obviously to read a higher oxygen content due to the oxidizer present
Re: (LS-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">Like what?</TD></TR></TABLE>
the zex kit comes with a NMU box that manipulates the FPR vacuum to increase fuel pressure under spray.
Re: (raceACCORDingly)
14.3 A/R on the motor? Thats pretty lean too. You should be more like around 12.8-13.5 and 13.5 is one the high side.
I would make sure that your vacuum lines for the nos kit are connected right. Sometimes the vacuum lines blow off and will cause it to run lean.
And I think a .042 jet is a 125shot on a dry kit. I ran a .036 on my 70 shot dry with no problems.
integraautox
03-04-2003 05:50 AM
