Fuel pump now?
Old Oct 1, 2001 | 06:38 PM
TurboSedan's Avatar
New User
Default Fuel pump now?
Would there be any negative effects to installing a high flow, high pressure Comptech in tank fuel pump before turbocharging? Thank you.
Old Oct 1, 2001 | 08:08 PM
TurboInteg95's Avatar
Default Re: Fuel pump now? (97CivicFerio)
you pretty much need an inline fuel pump, unless you're using the greddy kit.
Old Oct 1, 2001 | 08:10 PM
TurboSedan's Avatar
New User
Default Re: Fuel pump now? (TurboInteg95)
No Greddy kit for me, I will be putting together a custom T3 setup.
Old Oct 2, 2001 | 03:10 PM
TurboSedan's Avatar
New User
NE1 else have anything to add?
Old Oct 2, 2001 | 11:05 PM
89hybrid's Avatar
So why wouldn't one be needed w/ a Greddy kit.
Old Oct 3, 2001 | 08:27 AM
DC2's Avatar
DC2
25 Year Member
Default Re: Fuel pump now? (89hybrid)
The Greddy kit runs at low, stock-like fuel pressures compared to the demands of a rising rate regulator that need 100+psi on a daily basis.
Old Oct 3, 2001 | 11:46 AM
89hybrid's Avatar
Default Re: Fuel pump now? (DC2)
So do I need the fmu
Old Oct 3, 2001 | 08:25 PM
DC2's Avatar
DC2
25 Year Member
Because the GReddy kit comes with an FCU (Fuel Control Unit) which fools the computer into running the 310cc injectors at stock-like fuel pressures. Thus, they do not supply the kit with a pump simply they don't think it's necessary
Old Oct 3, 2001 | 09:50 PM
89hybrid's Avatar
The greddy kit I have did not come w/ a black or blue box.
Old Oct 3, 2001 | 09:53 PM
89hybrid's Avatar
So the question remains. Do I need an inline pump to run at 5-6psi.
Old Oct 3, 2001 | 11:10 PM
89hybrid's Avatar
Come on guys. Somebody has the answer please tell me. Do I need an inline pump to run low boost?
Old Oct 4, 2001 | 05:07 AM
DC2's Avatar
DC2
25 Year Member
Yes you will, along with a boost dependent regulator. Unless you stumble upon a GReddy FCU....
Old Oct 4, 2001 | 06:50 AM
VTC_CiViC's Avatar
Think of it this way, with boost you must increase fuel. 2 ways of doing this, #1 is electronicaly, #2 is mechanicaly. The GReddy kit's handle this electronicaly with the use of their piggyback fuel unit that taps into the ECU altering it's readings and forcing the computer to add fuel when needed. If you don't have a piggyback unit or other electronic fuel managment unit (and I don't mean V-AFC's or the like), then you have to add fuel manually which is when you'll want a higher volume pump and FMU.
Old Oct 4, 2001 | 06:53 AM
TurboSedan's Avatar
New User
Default Re: Fuel pump now? (VTC_CiViC)
Ok, but will it hurt anything by installing a high flow fuel pump on a stock engine? That was my initial question, and it did not get answered. Thank you.
grocerygttr18t
Aug 5, 2004 10:56 PM
jdkornlp
Nov 4, 2003 03:50 PM
E-spec Tuner
May 7, 2003 02:05 AM
turboD16
Jun 2, 2002 01:09 PM
