cp pistons - d-series - ring gaps
Old Jul 10, 2004 | 05:48 PM
pip9's Avatar
Default cp pistons - d-series - ring gaps
What should i set my ring gap to? My setup before was srp's and i had them at .018 top and .021 bottom. Cp didn't list any specs for the rings? they are stock bore 9.0:1 compression. I heard you are suppose to scuff up new pistons. Is this true?
Old Jul 10, 2004 | 08:35 PM
eddyboy's Avatar
Default Re: cp pistons - d-series - ring gaps (pip9)
My friend and I had the same question a few weeks ago.
Heres the thread
https://honda-tech.com/zerothread?id=904607
Old Jul 11, 2004 | 08:08 AM
pip9's Avatar
Default Re: cp pistons - d-series - ring gaps (eddyboy)
thanks for the thread. I'm going to go with .018 top and .020 for 2nd. Do i need to file down any of the oil rings?
Old Jul 11, 2004 | 08:29 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote"> I heard you are suppose to scuff up new pistons. Is this true?</TD></TR></TABLE>Whoever told you that should have his face scuffed up instead of the pistons.
Old Jul 11, 2004 | 11:44 AM
eddyboy's Avatar
From what i've read, as long as the oil rings do not overlap you should be ok. When we did my friends rings we didn't need to file any of the oil rings.
Hope this helps
Old Jul 11, 2004 | 04:12 PM
pip9's Avatar
i didn't need to file the oil rings. I had to use my je rings for the 2nd ones b/c the cp rings that came with the pistons were too big (.024-.025). All the pistons are done and installed. thanks for ur help on the phone earl :crosses fingers: that everything else will go together w/o any more problems.
ninesecrx
Mar 5, 2007 04:44 PM
GoldenEGG
Aug 19, 2006 04:50 PM
Mr. Vapor
Aug 28, 2005 09:06 PM
Trailz-EX
Dec 1, 2004 07:50 PM
ActiveAero
Jan 2, 2004 11:51 AM
