Couple of quick question regarding downpipe & wastegate
Old Nov 25, 2007 | 07:06 AM
Powelly's Avatar
Default Couple of quick question regarding downpipe & wastegate
Just thinking that the O2 hole in the new downpipe is not far down enough to be able to connect to the standard plug? I know when i had my N/A manifold on the O2 hole was quite far down. How do peeps usually get round this? drill a new hole?
Also wondered why this wastegate has 2 vaccum ports on it? No instructions Gonna run 1 to my vaccum manifold and 1 possibly to my manual boost controller??
Thanks
Old Nov 25, 2007 | 07:48 AM
Blown90hatcH's Avatar
Default Re: Couple of quick question regarding downpipe & wastegate (Powelly)
Might want to fab up a bucket under the wastegate. That way when the wastegate falls off, your new bucket will catch it instead of running it over.
Old Nov 25, 2007 | 08:04 AM
NJIN BUILDR's Avatar
Default Re: Couple of quick question regarding downpipe & wastegate (Blown90hatcH)
At least a cable on the waste gate.Sucks running over your own parts.Anyway a wide band o2 will have a long enough lead for that location.Check out Tial online for your line hookup. http://www.tialsport.com. Support the waste gate down tube and it will last a little longer before it cracks and falls off.
Old Nov 25, 2007 | 08:24 AM
Powelly's Avatar
I know the parts are rubbish but gonna roll with what we have until the new manifold and turbo arrive! Thanks for the info regarding the wideband. If i did wanna run with the standard o2 would i just make a new hole further up the downpipe?
Old Nov 25, 2007 | 08:47 AM
Default Re: (Powelly)
Just deleate the std o2 in the engine management.
Old Nov 25, 2007 | 08:49 AM
answerd's Avatar
ok for the o2 sensor, i got this o2 sensor from autozone or someplace, and they sold some universal o2 sensors that you have to splice the wires and ****, but all u have to do is extend the wires for ur situation, it comes with a plug for your car and you have to connect and soder the wires or just twist them and put some tape on them, like i did they work good since i had it.
wait wtf u could just extend your wires from ur o2 sensor right now huh
Old Nov 25, 2007 | 08:53 AM
Powelly's Avatar
Thanks, i'm running Hondata S300 so if i don't really need it i ain't gonna bother. The ECU is just running a basemap at the mo so unsure if i need it until i get to the tuner?
Gonna get him to fit the wideband in the hole instead then if i don't need the standard one.
Old Nov 25, 2007 | 09:14 AM
Yes.You can just delete it in the software with s300.
Old Nov 25, 2007 | 09:16 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Might want to fab up a bucket under the wastegate. That way when the wastegate falls off, your new bucket will catch it instead of running it over. </TD></TR></TABLE>
catch pan ftw!
you can just extend the wires on the o2 sensor
bacnoonoi
Nov 11, 2008 03:02 AM
homicydalboy
Jun 4, 2007 06:12 PM
DsMWookie
Welding / Fabrication
Oct 21, 2004 03:27 PM
platinum00
Sep 22, 2003 10:39 AM
niedejb
Jan 26, 2003 07:46 AM
