Couple questions.
Old Apr 2, 2003 | 03:06 PM
Happyman's Avatar
Default Couple questions.
I'm pretty set on just turboing my del Sol si(d16y8) and just have a few questions. How much boost can the stock block handle? I'm gonna go with the apexi kit and was wondering how hard it is to install? I know the basics to installing a turbo but I may just get a shop to do it to make sure nothing gets screwed. How much power can the stock tranny/axels take? I may just run stock 6-7 psi on the kit but at the track I'll probably want to kick it up to whatever the block can handle. Any help is much appreciated.
Old Apr 2, 2003 | 03:20 PM
civicudesire's Avatar
Default Re: Couple questions. (Happyman)
That block can handle 8psi but you will need to get some fuel upgrades. Atleast a fuel pump and a fmu. Also I say install it yourself. Its really not to tough except for taping the oil pan which i would suggest you have a shop do for you. Also your going to feel better knowing that you did everything yourself and didnt pay a shop. Your probally looking at atleast $400 for the install. You might as well start to learn about doing engine stuff because a turbo setup needs to be taken care of. Good luck
k20tuner
Jun 25, 2006 06:40 PM
Shaka01
Jan 5, 2006 06:13 PM
IntegraMastaz
Aug 30, 2005 08:45 AM
lanojp1
Sep 20, 2004 03:45 PM
blu2ksi
Feb 4, 2004 11:33 AM
