which Cooling fan??
Old Oct 17, 2012 | 04:50 AM
wespirl's Avatar
Default which Cooling fan??
Which cooling fans do you guys recommend?? Having an overheating problem when AC is running and also when car is under load.
I live in Jamaica so outside temps are always in the high 90's
Car and mods are below:
96 boosted Type R Integra
fully built B18C block and head
spooling performance ram horn ac comp manifold
mishimoto 3 core half sized radiator
slim fan
Gonna change the fan firstly and see if that helps... don't think the 1 I have i pulling enough cfm's
Thanx for the help
Old Oct 17, 2012 | 06:15 AM
XxRoCkMaNxNEOxX's Avatar
Default Re: which Cooling fan??
slim fan
Thanx for the help
http://www.slimfan.com/12_Radiator_c..._p/13hcfan.htm
13" Spal...I will be using this with a custom shroud. SHROUD is the key
Old Oct 17, 2012 | 12:13 PM
TheShodan's Avatar
Moderator
SPAL Fans work WONDERS... Even in Negril, Monteray, Kingston, anywhere..
Old Oct 17, 2012 | 12:24 PM
VTEC+Mini's Avatar
I have a Spal fan and Go-Autoworks shroud. It works shockingly well. The Spal fan will "Hoover up" small animals and the shroud will direct them through the radiator.
Old Oct 17, 2012 | 12:28 PM
Spawne32's Avatar
spal 30101507, stay away from slimfan.com fans, thats exactly the fan im replacing, the bearings went almost 6 months after i bought it, finally replacing it because the noises are horrific.
Old Oct 17, 2012 | 02:14 PM
grumblemarc's Avatar
The Grumpiest
No problem with the slimfan.com fan here. More than a year running. Shroud makes the difference.
Old Oct 17, 2012 | 02:46 PM
Spawne32's Avatar
shroud makes a difference with bearing failure?
Old Oct 17, 2012 | 05:07 PM
The Grumpiest
That was not referring to bearing failure, but cooling ability.
Old Oct 17, 2012 | 06:38 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
im running a Zirgo 14in on my half core, works very well!
Old Oct 18, 2012 | 12:07 PM
Kentour69's Avatar
Same here works great..
Old Oct 20, 2012 | 04:23 AM
wespirl's Avatar
thanx for the help guys... appreciate it
naa10104
Honda CR-V & Element
May 17, 2018 09:23 PM
kholmes
May 11, 2005 08:39 PM
jazz215
Aug 23, 2003 10:48 PM
itr449
Apr 14, 2003 05:41 PM
