Compressor Outlet leaking oil.
Old Oct 27, 2008 | 06:50 PM
1badteg's Avatar
Default Compressor Outlet leaking oil.
Turbo has 5k miles on it. seals seem to be good. It was leaking about 2 months ago, found out that the intake pipe was getting blowby from the vc. put a filter on the line and it stopped. checked it the other day and its leaking slowly. my feed line doesnt have an restricter. i have an edelbrock turbo kit on a ej8 d16y8 motor. running 7psi. thanks
Old Oct 27, 2008 | 07:20 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Compressor Outlet leaking oil. (1badteg)
do you have a crank case vent set up? hows your oil return?. what type of turbo
Old Oct 27, 2008 | 08:25 PM
1badteg's Avatar
i have a crank case vent setup, but it recently got cloudy/milky and i think it had moisture in it and froze, (20 degree weather in alaska). So you think since its not venting it could be drawing oil thru the intake again? oil return line has been ziptied to have a straight shot to the oil pan. the turbo is a gt28rs.
Old Oct 28, 2008 | 03:00 PM
1badteg's Avatar
Default Re: (1badteg)
bump!
Old Oct 28, 2008 | 07:45 PM
platinum00's Avatar
When you clocked the turbo, did you tighten the bolts correctly. I have seen them come loose.
-platinum
blk96coup
Jul 28, 2008 11:33 AM
bubbleboy22
Jun 18, 2007 03:26 PM
Blkteg97
Nov 16, 2004 08:04 AM
z6
Jun 3, 2004 11:03 AM
boostedlude3g
May 22, 2003 04:46 AM
