Compression test from Boost since April this year...
Old Dec 26, 2001 | 04:27 PM
GSRwBOOST's Avatar
Default Compression test from Boost since April this year...
I have seen 14psi on several occasions accidentally, a couple times the ground came off the battery (where the aux pump is wired to...now bolted to frame).. and several other little things... and a bunch of races...
~190 in all cylinders a hair off on one or two but I'd say 190 across the board.
a little fresh oil on the plug threads closest to the cam gears, plugs looked good other than that.
reset ecu and let it idle..... idles good.
This weekend is a day to finish the wiring of my BTM and crank it from 10psi to 12psi and after everything settles and goes well there for a couple weeks.. it's up to 14psi and a dyno tuneing.. I won't RUN 14 except for a dyno tuneing and one of the big boys that might necessitate a little extra umph from my tiny little inferior 4 cylinder honda engine...
It was this time last year that i discovered cracked ringlands... just celebrating my anniversary.
Old Dec 26, 2001 | 04:37 PM
GSRwBOOST's Avatar
Default Re: Compression test from Boost since April this year... (GSRwBOOST)
BTW: I have 9-1 compression pistons if your wondering why the numbers are lower than a normal GSR.
Old Dec 26, 2001 | 04:42 PM
quikrpm'z's Avatar
lucky you. Did u fix the other problems?
Old Dec 26, 2001 | 04:52 PM
GSRwBOOST's Avatar
Default Re: Compression test from Boost since April this year... (quikrpm)
well.. the car idles fine now.. so i dont know what reseting the comptuer did, but i'll know tomorrow..
i have a couple more things to try if it does the same thing.... but so far no codes, just a rough idle after a first stop... then it will settle down to an idle.
im going to replace the IAC i bought from the dealer (known good) with the one in the car, just to be sure. recheck vacume lines and go from there.
i also want to replace the FPR, i think that might have a problem too..
... ah the never ending quest for more power.. LOL
89hatchy
Jun 18, 2007 06:45 PM
4thgenner
Mar 13, 2006 10:43 AM
civic_driver
Sep 2, 2005 01:18 AM
Bulldogg83
Oct 13, 2004 04:36 PM
Turbolude
Oct 23, 2001 10:46 PM
