oil change.
Old Dec 26, 2001 | 04:14 PM
quikrpm'z's Avatar
Default oil change.
do u guys add any additional oil, or should i just use 4qrts(b18b1)?
thinking of using 10w40 pennzoil, and a fram oil filter. Is this a good weight to use of oil, and is there a better oil filter to use also? This is my first time changing the oil on the teg, do u guys just lift the car on the driver side? tia.
Old Dec 26, 2001 | 04:23 PM
JM Performance's Avatar
Default Re: oil change. (quikrpm)
use as much as you need to to get the oil between the two dots on the dip stick.
Old Dec 26, 2001 | 04:26 PM
dustin's Avatar
Default Re: oil change. (00SilverLS)
Hmm, fill to the top dot since that is full. Unless you want to be running low on oil all the time.
Dustin
Old Dec 26, 2001 | 04:33 PM
quikrpm'z's Avatar
Default Re: oil change. (dustin)
so i should add the 4qrts. let it sit, if its not up to the 2nd dot just add more.
10w40 pennzoil, fram filter< any input?
also the best (safest/easiest) lift point, center lift point, or the one by the driverside wheel. thx, guys.
Old Dec 26, 2001 | 04:37 PM
dustin's Avatar
Well, you are supposed to check the oil when the motor and oil are warm and the car is off.
4 quarts will fill it though, so do not worry about it.
Dustin
Old Dec 26, 2001 | 05:13 PM
Also note that if your car is sitting for a long *** time (like a week) and can drain (plug out or oil pan off) it will take more than 4 quarts.
I know this should be obvious, but I thought I'd through it out anyway.
[Modified by 00SilverLS, 9:14 PM 12/26/2001]
LukieLuc
Jul 15, 2008 07:22 AM
DAMN its SiJ
Honda Civic (2006 - 2015)
23
Jul 3, 2008 06:10 PM
polishprinze
May 13, 2005 09:21 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
SchEmE
Oct 13, 2001 10:33 AM
