Did a compression test today.
Old Oct 22, 2001 | 07:52 PM
Turbolude's Avatar
Default Did a compression test today.
187 accross the board after cranking it many times. Seems a little lower than the last time i did one, but im just glad they are all the same. What numbers are you guys gitting?
Old Oct 22, 2001 | 08:03 PM
SHystrdyGSRtdy's Avatar
Default Re: Did a compression test today. (Turbolude)
How much was the compression test?
Old Oct 22, 2001 | 08:45 PM
Turbolude's Avatar
Default Re: Did a compression test today. (iLUVmySH)
All you need is a compression tester tool, i think you can get it from any auto store for about 30 bucks. My friend had one, so it was free.
Old Oct 22, 2001 | 10:25 PM
976's Avatar
976
New User
Do it yourself, takes only ten minutes...
Old Oct 23, 2001 | 04:27 AM
boomslang's Avatar
Default Re: Did a compression test today. (B21A)
Are you doing the test right with the engine warm?
I get 195-205 on all of my cylinders. H23 with 75K on it.
Old Oct 23, 2001 | 07:05 AM
Turbolude's Avatar
Default Re: Did a compression test today. (Inlinefour)
Engine temp was 136 degrees, when it is fully warm it reaches 158. I did a test about a month ago and if i remember correctly i hit 210 across all for cylinders. But just recently a shop was tuning my car and the boost controller wasnt working properly and i hit 10lbs of boost and had a a/f ratio of about 15.6. Soon after that i found that my fuel regulator went bad. I would have thought that if i had fucked something up that the numbers would have been differenent than each other. Anyhow, i have 107,000 miles on the motor.
Old Oct 23, 2001 | 10:46 PM
Backyard Speical's Avatar
yeah that compression does seem kind of low. i have a 92 jap prelude motor and it made 220 all the way across. did you crank the motor 5-7 times?? try again maybe you'll get different resluts
http://www.prodigyworks.com
76 camaro car
Apr 20, 2017 04:47 AM
efking1985
Jul 26, 2010 02:13 PM
laocivic
Jan 9, 2008 09:21 AM
Jordan_4WS
Apr 23, 2002 02:58 PM
