Compression Numbers. Please help
Old Apr 24, 2002 | 06:45 AM
TRM04's Avatar
Default Compression Numbers. Please help
I know somethings wrong by just the outcome of these numbers. Please tell me what all of you think.
cyl 1=155
cyl 2=155
cyl 3=170
cyl 4=180
This is a GSR motor with 9:1cr JE pistons, Crower rods, STR block guard, and ARP head studs. If the car sits cold for a long time, it blows blue smoke out the exhuast and valve cover breather and then it stops after it's warmed up...sound like rings? It's done this ever since the turbo was re-installed after a rebuild.
Old Apr 24, 2002 | 07:19 AM
Flamenco-T's Avatar
Default Re: Compression Numbers. Please help (TRM04)
from what you describe on the smoke, sounds like rings...
are you getiing any misfires code ?
if I were you, I'd try to get a leakdown test....I mean you could just cracked the ring(s) barely, since your compresion is not too low...
when I craked mine, my comp were 100, versus 210 on the other three...
NOTDISFA5
15
Sep 26, 2010 06:27 PM
RedCd5TX
May 10, 2008 06:14 AM
batboyvaj
May 1, 2007 09:10 AM
crvtkllr
Sep 26, 2006 05:30 PM
Keith Pierson's bitch
Nov 24, 2005 11:10 AM
