smokin from vc
Old Sep 24, 2006 | 03:04 PM
crvtkllr's Avatar
Default smokin from vc
i have a fully built b16t and ive noticed after driving it hard it tends too smoke a lil bit from the vc vent is this normal? i sure hope so...
Old Sep 24, 2006 | 03:54 PM
A.E Motoring's Avatar
Default Re: smokin from vc (crvtkllr)
do a comptest, and/or leak down, see wat u come up with and come back
Old Sep 24, 2006 | 04:03 PM
crvtkllr's Avatar
Default Re: smokin from vc (SPNFEDEH)
so if you want me to do those test then im guessing it shouldnt smoke from the vc vent then. btw it does have low comp. pistons. can it just smoke from it being extremly hot????
Old Sep 24, 2006 | 04:04 PM
if your smoking from the VC, could mean your getting blow by
Old Sep 24, 2006 | 04:15 PM
crvtkllr's Avatar
blow by wtf is that is that a fancy way of saying my motor is about too blow up??? lil help here.
Old Sep 24, 2006 | 04:21 PM
Calvinator's Avatar
blow by is when compression is blowing past the rings, through the valve cover. I have a feeling your rings are going out.
Old Sep 24, 2006 | 04:27 PM
crvtkllr's Avatar
Default Re: smokin from vc (xtremeazian)
the car is only been boosted for about 10k miles and the most boost its seen was maybe 15lbs other then that it stays at 12lbs cause it hasnt been tuned yet. So you really think the rings are going out???
they are je 9.1 pistons so if i did do a comp test anybody have an idea of what the numbers would be??
Old Sep 24, 2006 | 04:58 PM
damn your boosting a motor on that many pounds untuned? u got alot of ***** doing that, wats the set up anyways? compression should prolly be around 180-190 across
Old Sep 24, 2006 | 05:16 PM
crvtkllr's Avatar
b16t, je pistons9:1
eagle rods
stock sleeves with 81.5mm bore
all arp studs and bolts
balanced blu printed bottom end
P and P head with skunk 2 lc valves, retainers
gsr cams
precision 580cc inj.
t3/t4e .57trim/61ar.
the set up was tuned on crome pro with a turbonetics t3 with 12lbs then switched too t3/t04e and havent had it tuned yet but hoping for 400whp...
Old Sep 24, 2006 | 07:48 PM
Calvinator's Avatar
I wouldnt have even boosted all at if you werent tuned. You were basically tuned for that baby t3 and you switched to a bigger turbo, which is flowing a lot of air than that baby t3. Do you a leakdown and compression and let us know. I have a feeling you messed up that motor.
10k is a lot of miles to go untuned.
Old Sep 24, 2006 | 07:52 PM
ragethemachine86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr &raquo;</TD></TR><TR><TD CLASS="quote">... hasnt been tuned yet. </TD></TR></TABLE>
all that work for nothing
Old Sep 24, 2006 | 08:04 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr &raquo;</TD></TR><TR><TD CLASS="quote">the car is only been boosted for about 10k miles and the most boost its seen was maybe 15lbs other then that it stays at 12lbs cause it hasnt been tuned yet. So you really think the rings are going out???
they are je 9.1 pistons so if i did do a comp test anybody have an idea of what the numbers would be??</TD></TR></TABLE>
damn well if thats the case then you should be fine. ONLY 12-15psi untuned aint a problem...
Old Sep 24, 2006 | 09:30 PM
turbotime's Avatar
you prolly blew your rings or ringlands.
9:1 pistons on my b17 yeilded 180 across the board. Yours will be close if not the same, just look for differences between cylinders. whats your pcv [positive crankcase ventilation] setup?
Old Sep 25, 2006 | 05:43 PM
crvtkllr's Avatar
Default Re: (turbotime)
i dont have any type of special set-up for my pcv just left it the way it always have been, is there a certain way it should be hooked up??????????
Old Sep 25, 2006 | 05:51 PM
turbotime's Avatar
how do you have it hooked up exactly? There are 2 pcv points in the stock setup:
1. Valve Cover -&gt; Intake Arm
2. PCV Valve -&gt; Intake Manifold
I assume you just have a breather on the valve cover right now and #2 still hooked up as stock?
How much boost are you running? See my sig for the proper way to hook it up you need a "catch can"
Old Sep 25, 2006 | 05:56 PM
crvtkllr's Avatar
i have no breather on the valve cover and the pcv to the im is hooked up stock, no catch can,
i also saw on a few b16t/b18t dyno pulls on line and they had a crap load of smoke coming out of theirs. Whats uppp with that????
Old Sep 25, 2006 | 06:55 PM
turbotime's Avatar
so where does the line from the valve cover go on your setup?
Old Sep 25, 2006 | 07:10 PM
lakai_19's Avatar
http://www.youtube.com/watch?v...earch=
watch this video this guys car does it on dyno and they dont look to concerned about it
Old Sep 25, 2006 | 07:35 PM
turbotime's Avatar
i was under the impresseion the car smoked at idle after a hard run, not during a hard run... how could u even tell?
Old Sep 26, 2006 | 08:26 AM
crvtkllr's Avatar
i have no line on my valve cover it just goes out to the atmosphere,
and it does smoke a lil after a hard run and i can tell because i can open my hood up and look at it after the hard run....
the easy way to explain would be to watch the video that lakai_19 posted my car does the exact same thing.... is that normal????
Old Sep 26, 2006 | 02:29 PM
crvtkllr's Avatar
Default Re: (crvtkllr)
so should there be some type of line coming off the valve cover???
Old Sep 26, 2006 | 05:30 PM
Danny_EJ's Avatar
A little steam coming out is ok, it is piping hot inside the motor and any engine that has been running especially on the dyno after a pull will steam slightly.
Now if its forcing /puffing out of the breather you may have bad rings/ringlands
socialistic
18
Jul 1, 2011 04:31 PM
GTEater
Sep 30, 2010 09:43 PM
1sikhatch
Apr 26, 2007 02:22 PM
DSRxMilogen
Mar 28, 2005 07:24 PM
S2KP
Oct 24, 2003 03:39 AM
