hondata ?
Old Apr 24, 2002 | 01:29 AM
UnderPressure's Avatar
Default hondata ?
I'm planning on running 6psi on a b18b...
Do I send in my 'puter to hondata for modification?
They then mail it back with a base program?
and then I have to find someone to tune it for my boost application?
Can I just get a program that will work for 6psi?
nowhere in Colorado tunes Hondata **** yet..
thanx peace
Old Apr 24, 2002 | 05:36 AM
Anubyss's Avatar
Default Re: hondata ? (UnderPressure)
1. Yes you need to chip it. You can get another ecu and send that to them if you don't want to have down time.
2. Most likely they can pick the best program suited to your needs.
3. Most defintely yes.
4. No, you should have it tuned for YOUR car to be safe.
Old Apr 24, 2002 | 07:35 AM
JT's Avatar
JT
Yes, you will need to have your ECU modified. However, unless you are also buying the blue box from Hondata, they will only socket your ECU if you send it in. Which means, it will not come back with any base program. It's up to the dealer that you purchase the Hondata system to provide the base program.
Hoodwinked
Jan 5, 2005 01:11 PM
aziz93
Aug 16, 2004 08:29 AM
JunIntegra
Apr 8, 2004 06:44 PM
speedyonez
Oct 20, 2003 06:49 PM
