compression numbers help me out here.
Old Jun 2, 2003 | 11:21 AM
Tetronious's Avatar
Default compression numbers help me out here.
hey,
i did a compression test on my 2000 SI the other day and came up with these numbers all four were around 180-182.. I cranked the engine five times and all four of them got up around that number and stayed. I even did it at WOT. Do those numbers seem a little low? The car has like 47,000 miles on it. I just put a Greddy 18G Kit on it just recently. The kit hasnt been on the car for no more than 200 miles. I thought the B16 was up around 200-210? Is this because of the mileage or more of a problem..??
Old Jun 2, 2003 | 01:50 PM
rainmanEK's Avatar
big strong guy
Default Re: compression numbers help me out here. (Tetronious)
Around 200 seems a bit Closer to normal, When I Checked compression on my old B16a SIR2 engine I had 215 on all four!
Eric
Old Jun 2, 2003 | 01:51 PM
salt's Avatar
was the engine hot when you did this or had it been sitting a while ?
Old Jun 2, 2003 | 03:37 PM
FredoSP's Avatar
I have 71k on my 2000 Civic Si, Ive had the greddy kit on there since 53k, no problems. My last compression check was 195 185 195 210, im happy with those, but i need to get a leak down test just to be sure. You should get a leakdown test too! We always cant go on compression #'s alone.
Hope this helps
Fred
Old Jun 2, 2003 | 03:51 PM
tegasaurus's Avatar
Default Re: compression numbers help me out here. (FredoSP)
i hate to hijack this thread with suck and obsurdely n00b question... but what exactly happens in a leakdown test and how do you get your results etc?
-ryan
Old Jun 2, 2003 | 03:52 PM
gzrmoto's Avatar
did you have all the spark plugs in that will matter in the compression
Old Jun 2, 2003 | 03:57 PM
FredoSP's Avatar
Default Re: compression numbers help me out here. (gzrmoto)
Leakdown test .. basically how much air is escaping from each cylinder ...
You want the lowest drop in the percentage. you typically want between 100%-96% The drop in percentage is the amount of air you are losing. for example 100% means there are no leaks. 98% means 2% of the air is escaping the cyclinder tested. anything more than 4-6% is a big loose and you want to look into it. This is coming of the top of my head.
- Fred
Old Jun 2, 2003 | 03:59 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gzrmoto &raquo;</TD></TR><TR><TD CLASS="quote">did you have all the spark plugs in that will matter in the compression</TD></TR></TABLE>
I dont think it matters, as long as no fuel is going to the cylinder .. i usually unplug the injectors or pull out the fuse (I forgot which one .. 7.5 AMP I think EFI??). I just take each plug out as I go to each cylinder.
Old Jun 2, 2003 | 04:01 PM
FredoSP's Avatar
Default Re: compression numbers help me out here. (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">i hate to hijack this thread with suck and obsurdely n00b question... but what exactly happens in a leakdown test and how do you get your results etc?
-ryan</TD></TR></TABLE>
Damm Im a mess today, The best leakdown testers use two gages. One monitors the supply pressure (usually set to 100 PSI). The other monitors the cylinder being tested. Leakdown tests are the BEST way to evaluate cylinder sealing.
Old Jun 4, 2003 | 03:02 AM
Tetronious's Avatar
i took all the plugs out and popped the distrubtor cap off and unplugged the 15 amp fuse under the car and then did the test. I also had just got done driving the car about 20 miles or so.. I had to let it sit for awhile because it was still hot from driving plus it was freaking raining outside so I had to wait a bit longer.. I say it was about 30-45 minutes before I actually got to do the test.. Im betting that was probably why it was low to begin with.
Old Jun 4, 2003 | 07:59 AM
vha27's Avatar
and remember, the 1st puff should be at least 50% of what the final reading is, if its not this indicates worn piston rings
Hondizzle!
Sep 13, 2005 09:13 AM
Greenery18
Jul 6, 2004 08:29 AM
speedymon
Jan 10, 2003 08:02 AM
Norcalstoppy
Nov 21, 2002 12:55 PM
boost killz
Aug 19, 2001 03:31 PM
