setting pistons rign end gap
Old Jun 3, 2003 | 05:40 PM
Boostless97Lude
Guest
Posts: n/a
Default setting pistons rign end gap
the wiseco piston ring i have say .004" per 1" or bore, so i fiugre with an 89mm bore, it's about 3.5" then it's .014", except for "some" applications, which means it needs a little more gap.... what would be a good ring end gap for me, like .016-.018?
Old Jun 3, 2003 | 08:38 PM
Flamenco-T's Avatar
Default Re: setting pistons rign end gap (Boosted97Lude)
first ring .019
second ring .014
Although I set both of mines on the old setup at .018, 81.5 mm bore .20 over
stan
Old Jun 4, 2003 | 05:33 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: setting pistons rign end gap (Flamenco-T)
ok, i set mine at .018-.019 top ring and .014-.015 2nd ring (it's damn hard to get those things perfect)
Old Jun 4, 2003 | 08:04 AM
earl's Avatar
should be fine
Old Jun 4, 2003 | 08:07 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: setting pistons rign end gap (earl)
thanks
civic-steve-94
Engine Machining & Assembly
Sep 16, 2016 04:20 PM
turbodcxbro
12
Jul 4, 2011 08:43 PM
mvp100
Feb 22, 2008 07:06 AM
Aeka GSR
Sep 28, 2003 05:40 PM
Thats-so-Ls
Dec 29, 2001 07:17 AM
