Compression test results (gsr)
Old Jan 10, 2003 | 05:19 AM
speedymon's Avatar
Default Compression test results (gsr)
Yesterday I did a compression test on my 1996 GSR. I've been boostin 7lbs for 6k miles and I have 102k miles on the odometer. Stock engine w/ Mobil 1 syn. Numbers are from cyl 1-4: 235, 235, 230, 235.
I think i cranked the engine too many times though (10). But the car was at operating temp and at WOT. Should i redo my test w/ only 5-7 cranks? Also i didn't look at the gauge to see how the pressure built up.
Old Jan 10, 2003 | 07:13 AM
brcivic411's Avatar
Default Re: Compression test results (speedymon)
not 100% sure, but once it's reached max compression, it will not go any higher.
Old Jan 10, 2003 | 07:59 AM
FredoSP's Avatar
those numbers look good, nothing really low. I just did a compression test on my Si last month .. 190 180 190 210. I believe the si has a drop lower compression that a GSR. Im sure those #'s are good. I have been boosted since october.
Old Jan 10, 2003 | 08:02 AM
TheHater
Guest
Posts: n/a
Default Re: Compression test results (FredoSP)
my comp. n# and im not even boosted 5,and the rest are close to 100
DAprojectTuRtle
May 1, 2010 02:03 PM
Boostin_GSR
May 23, 2007 01:12 PM
guero2craze
May 8, 2007 09:15 PM
Greenery18
Jul 6, 2004 08:29 AM
MechEng
Feb 11, 2002 06:15 PM
