compound charged built GSR opinions.
Hey
Want to try someting different here in UK for my EG9. Want to do a compound or series turbo setup for my civic. Running a built B18C4 (GSR-ish) with stock sleeves. Want about 500ish bhp but good spool etc as gets used on track lots as oppssed to drag. It will attract the crowds here too which is kinda what I need to build for as I work for Race-tech. Thinking of using Bullseye 248/256 and then either a 366 or 372 for the largr one. Want to use single 60mm or twin 46mm gates. Any input guys? Marc
Re: compound charged built GSR opinions.
I think I can make a broader power band with a compound setup. A 10 sec drag car and a track car are two different animals. Most of the fast cars on here would get eaten by some NA Honda's on track. I did 400whp on my last build but was too laggy, didnt wake up till after 5500rpm. I want good bottom end and strong top end, think this may work. Who tried it? Ill check them out? Cant find anything on youtube/here?
a gt28r and a gt35r would work a little nicer. spool fast until the 35r catches up at about 5k rpm. i looked into it for a little while. i just said screw it and bout a dbb 6262 billet. thats what brake boosting and preloading is for.
http://www.atsdiesel.com/ats2/templa...029422272&c=36
Basic idea of it is here for anyone interested and unsure of what i mean.
How do you plan on applying your broad powerband to the ground? As much as I love FWD Honda's they will always be traction limited in lower gears, 400tq at 3k rpm will be completely useless. Also where do you plan on fitting all of this at? I have seen a few compound setups they are a maze of plumbing, flanges and everything else.
Il run 17" slicks on track off BTCC cars, it puts it down pretty well so Im not too worried about that. Also will have boost by gear so makes life easier. Im gonna put larger one in front bumper back door style. The Slam panel will have to go like, but like our sister car we have here, we will prob make a full alloy cooler/rad/slam panel front end in one assembly that bolts on to chassis legs. They look cool as. Mani and stuff isnt that complex TBH. Hardest part is turbo sizing to ensure efficient.
so your going to dial out all the low end gains with boost by gear, so whats the point of all of this besides a bling factor and adding unnecessary weight?
Maybe I'm weird, but on the track I only need a 3k powerband on reasonable gearing.
If you drive like you should spool time should'nt be much of an issue. If you find yourself mashing the throttle and waiting for spool to happen, you drive like a moron!
i think a lot of guys are bringing street related comments in, almost would have to be
i was talking about circuit racing
if your driving along the race line and you are approaching the clipping point in the right gear you should'nt be that low in your gear (on a honda there's no need to drop below 6000rpm), when reaching the clipping point you're already feeding in the power as traction alows and there's no wait for spool as you're already slowly feeding in the power.
if you drive like a moron you'll find yourself mashing the throttle somewhere and waiting for boost. if you know how to drive you won't have that problem.
also gearing is key to stay in your powerband
Man U FTW
You're going about this all wrong. Why would you try to make 500hp from two turbos, when the smaller of which (s256) can already reach the goal you have set? If anything, you would run an S258 as the larger of the two turbochargers with something smaller, say a GT2871r running into and spooling the larger turbo. Having said that, i'm not accounting for the synergistic goodness that happens in compound setups...the larger turbo doesn't need to be even as large as the s258 since the smaller turbo will also be adding to the overall flow. To find the golden combination for your car/goals, you'll need to talk with someone a little more versed in fluid dynamics and turbocharger systems. A few people come to mind: TheShodan, Tony1 and Tony the Tiger (all HT members)
You dont need that much power. Look at William Chans setup. That makes not a whole lot more then 300whp and he is crushing it.
http://www.youtube.com/watch?v=EaITwajoilA
KilowattBandit
07-03-2019 12:16 AM
