Cometic .56 Gasket on stock LS turbo setup
Old 08-10-2004, 11:40 AM
f22suzuka's Avatar
Default Cometic .56 Gasket on stock LS turbo setup
I have a new cometic HG .56" thick that I was going to use on my gsr before I sold it, I was wondering if it will work on my stock bore LS turbo set up. will this allow me to up the boost b/c of the drop in compression. Or should I just keep the stock HG? any input would be great.
Old 08-10-2004, 12:02 PM
Moderator
TheShodan's Avatar
Stock Headgasket is fine. The LS is already lowered from the factory to 9.2:1. Any lower than 9.0 and idle becomes very questionable.
Just use the stock HG
Old 08-10-2004, 12:11 PM
Cyphear's Avatar
Default Re: Cometic .56 Gasket on stock LS turbo setup (blackout95teg)
I could be wrong, but i'm almost postitive Cometic (or anyone) doesn't make HGs near that thick. The thickest MLS headgasket that I know of that cometic makes is a .12 and for honda B-series is a .078. That head gasket would drop a LS compression ratio to like 6:1.
Old 08-17-2004, 03:29 PM
B00ST2nR's Avatar
Default Re: Cometic .56 Gasket on stock LS turbo setup (Cyphear)
he most likely meant 0.056
Old 08-17-2004, 04:11 PM
14bcoupe's Avatar
Default Re: Cometic .56 Gasket on stock LS turbo setup (B00ST2nR)
i wouldnt do it the compression on the ls is already turbo friendly. lowering it this much will not help much unless your planning on boosting 20+psi which wont be good on stock pistons,and not to mention an even worse daily driver.
greencivic_0789
02-18-2010 09:20 PM
URNVS
06-17-2006 07:44 AM
soulless1
07-19-2003 06:26 AM
redteg
01-13-2003 03:18 PM
SlowPoke
08-29-2001 03:00 PM
Quick Reply: Cometic .56 Gasket on stock LS turbo setup
