codys- mini me mani help!
Old Oct 29, 2004 | 06:27 PM
  #26
braintree's Avatar
Default Re: codys- mini me mani help! (n20need4vtec)
Try clocking the turbo a tab bit towards te back. That might be enough to pass the rad mount.
:Edit: Just saw the second pic. It really does look like you will have to move the rad. It seems like the question now is where. Good luck.
Old Oct 29, 2004 | 06:32 PM
  #27
This One's Avatar
Default Re: codys- mini me mani help! (braintree)
DId you buy the manifold from cody, I dont think your left with no options.
Re-positioning the turbo inlet flange would fix the problem.
It looks it somehow got misaligned in the contruction process.
Its a simple fix, unless the setup is intedned for a completly different setup/car
Old Oct 29, 2004 | 06:34 PM
  #28
MrBui's Avatar
from the head to the core support i have about 10.25 inches....the turbo housing extends to 9.75 inches.... does anyboyd know how much space an integra has?
Old Oct 29, 2004 | 09:02 PM
  #29
FOrSfEd's Avatar
I don't see that ffiting at all. Hopefully Cody will see this with the new pics posted and have a suggestion cause I can say nothing but good things about him and lovefab.
Old Oct 31, 2004 | 06:57 AM
  #30
MrBui's Avatar
Default Re: codys- mini me mani help! (FOrSfEd)
it took a lot of work but i still dont think its right.... everything that touched the manifold had to be grinded down.....looks like i might have to find an integra condensor or make mine work some how.....but its in there.....i still dont think its made right...
Old Nov 1, 2004 | 07:16 AM
  #31
Tinker219's Avatar
Default Re: codys- mini me mani help! (This One)
The four bolt turbos fit a lot better with this turbo location then the 5. This was built on the same jig that every other AC tubular manifold uses, and now that I think back, the majority of them have been 4 bolt turbos, or T4, hence no real problems because of the 1" closer to the block. I can reposition the turbo flange if youd like, just return it.
lambertincorp
Jan 2, 2008 08:10 PM
dturbo
Feb 16, 2005 05:45 PM
a2sportcompacts
Aug 11, 2004 09:21 PM
SiDelSol97
Jul 11, 2004 09:05 PM
SiRkid
Sep 29, 2003 06:49 AM
