Code 3 (map)
Old Feb 17, 2010 | 01:54 AM
2kdrift's Avatar
Default Code 3 (map)
so i have a code 3 map sensor on my del sol
this is due to my turbo and the map nreading out of range boost
i tried a missing link, as well as teh check valve trick always i still get code 3. i used 5 check valves becouse i have max boost of 10 lbs
so basically i need to chip my ecu so my map can read boost?
i really did not want to chip ECU ...what am i doing wrong ??
Old Feb 17, 2010 | 03:58 AM
94EG8's Avatar
Seagull Management
Default Re: Code 3 (map)
If you're running a turbo without a tune you're just asking for trouble. Missing link is an ancient hack.
Old Feb 20, 2010 | 03:08 PM
2kdrift's Avatar
yeaaaa im ording 440 cc injectors fuel pump and a chipped p28 from phearable.net
thanx mang
teg_95
Apr 28, 2009 07:19 PM
pwr_crx
Feb 16, 2006 10:01 PM
Cimburke23
Sep 13, 2004 05:23 PM
96dcek
Aug 20, 2004 02:40 PM
platinum00
Jul 25, 2003 09:16 AM
