Ecu Code 3 When In Boost
Old Aug 14, 2003 | 12:35 PM
Fatty_1775's Avatar
Default Ecu Code 3 When In Boost
When I go into boost, sometimes I get a cel. It happens after 4000 rpms. It doesnt happen all the time. I checked the ecu and its a code 3 (map sensor). What do I do now? Also, it goes away when I turn off the car and restart it. Thanks.
Old Aug 14, 2003 | 02:02 PM
Burke's Avatar
Banned
Default Re: Ecu Code 3 When In Boost (Autobot_Killer)
yea i get all the time too. and my uberdata is supposed to cure that. buts its not. i dunno, ive tried different tunes, new map sensor, everything. and i can full boost for a little and then when it starts to build like in 5th or something, at like 2 psi - OFF it goes. im am just getting used to it
Old Aug 14, 2003 | 02:56 PM
The Crow's Avatar
Is your missing link on right? Do you have a AFC on your car?
Old Aug 15, 2003 | 12:19 AM
Fatty_1775's Avatar
Default Re: Ecu Code 3 When In Boost (The Crow)
I think its on right, isnt there only one way to connect it? It worked fine last year, before I lowered the compression. I dont have an afc.
Old Aug 15, 2003 | 03:02 AM
TypeDC4's Avatar
Ya I have the same problem, would an afc fix that? Or could it be a defective missing link. It only happens to me in 3rd and 4th gear while in full boost.
Old Aug 16, 2003 | 12:12 AM
Fatty_1775's Avatar
Default Re: Ecu Code 3 When In Boost (TypeDC4)
Does it happen all the time? It doesnt happen all the time for me.
EFing_bmxED
42
Nov 30, 2004 09:11 PM
Griffin@Camtech
Mar 19, 2004 01:16 PM
silverCRXTC
Feb 4, 2004 07:32 AM
2ltrsnailpwr
Oct 24, 2003 03:33 AM
ID_ten_T
Jun 9, 2003 03:06 PM
