Clutch 101 by Rocket
Old Jul 27, 2002 | 08:32 AM
  #151
mhx's Avatar
mhx
Default Re: Clutch 101 by Rocket (DunReit)
Spec clutches are for domestics.. I dont think they make em for hondas
Old Jul 27, 2002 | 03:27 PM
  #152
Screamer's Avatar
Default Re: Clutch 101 by Rocket (Rocket)
Hi, I find your post very interesting and it comes at a perfect timing. I am curently in the process of putting back together my build engine for turbo and I am at a stage when I am about to put my tranny back on to the engine. I was previously running a N/A setup, but knowing how important the clutch is I used the ACT extreme pressure plate with their street/strip disk. Well the pressure plate did keep up with my aggressive driving but the disk just like you have said was very close to failing. The splines were almost gone and one of the springs started coming out. Now for my question. I am running a Toda flywheels 8lbs with the ACT extreme pressure plate and just ordered an un-sprung organic copper 4 puc disk. Will this combination be good for my planed 320-350whp and what problems should I expec? Thanks, you are doing a great job.
[Modified by Screamer, 6:43 AM 7/30/2002]
Old Jul 27, 2002 | 06:54 PM
  #153
John's Avatar
New User
Default Re: Clutch 101 by Rocket (mhx)
No, he has one in his 2.44L H motor and hasn't had a problem since.
Old Jul 27, 2002 | 08:52 PM
  #154
GSRwBOOST's Avatar
Default Re: Clutch 101 by Rocket (Screamer)
I'm not sure on this.. but clutches are measured by the amount of torque they can handle..
I have the ACT XTR6 and the R6 will hold 400lbs torque, and i think the clutchmasters stage 3 held around 300lbs...
I was unsure about the R6 until I drove a hatch today at the shop I goto and after 5 minutes of driving it.. it really wasn't as bad as everyone claimed... I'm installing mine in the morning.. and we shall see how the xtreme pp is compared to the ACT hd pp that i drove today..
Old Jul 29, 2002 | 04:45 PM
  #155
Rocket's Avatar
Screamer, ACT disc will eat into your flywheel and your flywheel will have to go bye-bye.
Get a disc with Miba pads like Actions and you'll be cooo. Or you can step up and use Kevlar pucks.
[Modified by Rocket, 1:46 AM 7/30/2002]
Old Aug 8, 2002 | 06:08 AM
  #156
The Rob's Avatar
What clutch do you recommend with an all motor integra which has 175whp and 138ft-lbs of torque? Daily driven, wont kill my flywheel.
Old Aug 9, 2002 | 12:00 PM
  #157
Rocket's Avatar
Default Re: Clutch 101 by Rocket (Zero Effect)
1MD is perfect. Also a 1KD(Kevlar pads) is the ultimate.
Old Aug 9, 2002 | 01:12 PM
  #158
IM ALL BOB's Avatar
I can say the Stage 1 KS is perfect for me.. Rocket helped me make a better choice on what I wanted.. and all I can say is that the KS is smooth like butter =P thanks robert for you and all the guys at hondasaver
[Modified by IMALLBOB, 2:12 PM 8/9/2002]
Old Aug 15, 2002 | 10:53 PM
  #159
*Boostwerks*'s Avatar
Bump for an outstanding company....
^^^^HondaSaver RULES^^^^
Old Aug 20, 2002 | 03:31 PM
  #160
Rocket's Avatar
Default Re: Clutch 101 by Rocket (Bryson)
Thanks Bryson. So howz your custom Action disc.
Old Aug 20, 2002 | 08:17 PM
  #161
SoulSurfer's Avatar
I would have to make the same bump...Rocket was more than helpful. He answered all my questions (no matter how stupid) and was very quick to send the clutch I ordered. I will definitely do business with them again!
Old Aug 20, 2002 | 09:33 PM
  #162
GREAT!!!!....I made a post under the CRX/EF forum....heres the link
Thanks once again Rocket....
BTW, How long do you think this clutch will last with daily driving? i understand that there are many factors in this, but how long have you seen this setup last?
heres the page....
https://honda-tech.com/zerothread?id=257100
Old Aug 22, 2002 | 12:13 PM
  #163
Rocket's Avatar
Easily 3 years.
Old Aug 22, 2002 | 03:29 PM
  #164
98EK4's Avatar
Default Clutch 101 by Rocket (Rocket)
Rocket, I have a Clutch Specialties Unsprung 6 puck Dual Diaphram. It has alot of chatter when engaging. Does that create alot of wear on my tranny or is it just wearing on the clutch itself. Thank you for you time
Old Aug 22, 2002 | 03:36 PM
  #165
Rocket's Avatar
Default Re: Clutch 101 by Rocket (98EK4)
Yes. Sparkz just came by my house to show me his CS clutch and it was toast only after 3K miles.
Old Aug 22, 2002 | 05:25 PM
  #166
sparkz's Avatar
Yep, I probably had not even close to 3k miles on the clutch specialties aluminum flywheel setup. The pads on the flywheel side were all worn down to the rivets already. My aluminum flywheel was just fubarred, very scarred up. Rockt has a picture of it so I hope he can post it up soon.
Old Aug 22, 2002 | 05:58 PM
  #167
NaVamous's Avatar
Default Re: Clutch 101 by Rocket (sparkz)
I got my Action Clutch yesterday, Thanks Rocket!
Old Aug 23, 2002 | 05:58 AM
  #168
soooo.....
how long would the 6 puck setup last with the kevlar pads?
Forever...... ?
HondaSaver
Old Aug 23, 2002 | 11:08 AM
  #169
Rocket's Avatar
soooo.....
Forever...... ?
HondaSaver
Practically forever.
Old Aug 23, 2002 | 11:14 AM
  #170
sweet!!!
I'm on the list to buy that setup from you next year!! (for my new motor)
Old Aug 24, 2002 | 01:45 AM
  #171
Rocket's Avatar
Here it is. It's fucked up. The band in the middle is from the rivets!
Old Aug 24, 2002 | 01:58 AM
  #172
Dee's Avatar
Dee
Great post but I'm gonna stick with using OS Giken clutches until I get dumb enough to blow lots of loot on the ATS carbon clutch!
Old Aug 24, 2002 | 02:08 AM
  #173
Rocket's Avatar
Default Re: Clutch 101 by Rocket (Dee)
Can you sell me some ATS ****? Thanks.
Old Aug 24, 2002 | 02:16 AM
  #174
Rocket's Avatar
CLUTCH 101 cont....
PRESSURE PLATE ASSEMBLY
Here's the underside of a OEM P72(GSR) pressure plate
STRAPS
Here are the difference between the stock STRAPS and the STRAPS used by Action
Note that the Action STRAP is pre-bent. This prevents the STRAP from bending at the rivet. It is 100 times more likely to break if it bends at the rivet instead of bending at a pre-determined point away from the rivet. Also note the thickness of the STRAP. The material of steel is also superior.
Also not that the Action STRAP is shorter. This is important since the straps keep the friction ring centered in the cover. Stock straps some time can't keep the friction ring centered and on high HP turbo engines the friction ring tends to shif and hit the cover. Once this happens the clutch has a hard time releasing properly.
ACT also use their own STRAPS but I am not too impressed since they just use cut steel ribbon and do not have the pre-bent sections like Actions.
Here's a pic of what the stock STRAP looks like up close in the stock P72 pressure plate. Notice how the stock STRAP can bend at the rivet. This bending occurs when the STRAP is in compression (when you down shift). When you launch the straps are in tension (being pulled upon) there's no bending.
More to come.....
[Modified by Rocket, 11:23 AM 8/24/2002]
Old Aug 24, 2002 | 02:48 AM
  #175
Dee's Avatar
Dee
What ATS items interest you? I can't sell you anything since I'm merely a consumer but I can help you get some stuff.
