turbo problems! help!
Old Jun 12, 2002 | 07:26 PM
ezark's Avatar
Default turbo problems! help!
i was just about done installing my turbo after i upgraded it to a t3/t4; however, there is a small problem! the slave cylinder is in the way of the turbo!! the manifold is also off by 1/4". any help appreciated. thanks.
Old Jun 12, 2002 | 08:02 PM
boomslang's Avatar
Default Re: turbo problems! help! (gsR-T mode)
Loosen the compressor housing and turn it.
Old Jun 12, 2002 | 08:04 PM
b18bvudoo's Avatar
New User
Default Re: turbo problems! help! (Inlinefour)
yup, clock that sucka!
Old Jun 12, 2002 | 08:55 PM
ezark's Avatar
Default Re: turbo problems! help! (vudoo666)
i tried!! but it only stays in that position, or all the way up only.
Old Jun 12, 2002 | 09:27 PM
Flamenco-T's Avatar
loosen all six bolts on the back of the compressor housing and turn it...
Old Jun 12, 2002 | 10:23 PM
ezark's Avatar
Default Re: turbo problems! help! (Flamenco-NA)
tried loosening those six and moving the compressor... does it require a lot of force? also, can i adjust to any position i want?
Old Jun 12, 2002 | 10:27 PM
PureTeg420's Avatar
no, and yes
Old Jun 12, 2002 | 10:29 PM
PrecisionH23a's Avatar
Default Re: turbo problems! help! (PureTeg420)
you might have to take it off the manifold to spin around, you can rotate it 360 degrees.
Old Jun 13, 2002 | 01:47 PM
greengangsta's Avatar
loosen all the bolts and take a rubber mallet and tap the compressor to free it up so that it can turn.
Old Jun 13, 2002 | 10:24 PM
turbopimp's Avatar
Hmm... looks as if maybe you can't rotate the compressor housing because it's wedged onto the web on the block... can't be sure, but in your second pic it looks as if the manifold nut isn't on all the way yet but the compressor housing is hitting the block... did you grind/notch the web? Most manifolds require this to work with T3/T4 hybrids...
Old Jun 13, 2002 | 11:09 PM
ezark's Avatar
alright guys, with all of your help- i got it!!! turbo feels good. once again, i can't thank you guys enough!
B18EG6
Jan 28, 2006 04:24 PM
youngkow
Jan 3, 2003 12:03 PM
Tofurky
Dec 7, 2002 04:48 PM
B18C-RnVA
May 5, 2002 05:30 PM
