choosing piston compression for more torque
Old Sep 2, 2005 | 03:43 PM
ramennoodles's Avatar
Default choosing piston compression for more torque
i'm looking into buying a set of pistons for my ls turbo. what I wanted to know is, would it make a difference in torque at the same horsepower between 9:1 compression ratio versus a 8:1 copmression ratio? would one have more torque than the other or will it be the same? or if someone could post a link to some good info, that would be cool
Old Sep 2, 2005 | 04:11 PM
nonvtecD's Avatar
9:1 is going to make more power throughout the RPM range. I used to be a fan of low compression but after driving my car which is spineless out of boost I think the next time I built a motor I would go at least 9.5:1
Old Sep 2, 2005 | 04:37 PM
boosted92's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">9:1 is going to make more power throughout the RPM range. I used to be a fan of low compression but after driving my car which is spineless out of boost I think the next time I built a motor I would go at least 9.5:1</TD></TR></TABLE>
You can <u>really</u> notice the difference between 9:1 and 9.5:1 on the street, too
Old Sep 2, 2005 | 04:56 PM
Default Re: (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
You can <u>really</u> notice the difference between 9:1 and 9.5:1 on the street, too </TD></TR></TABLE>
so is this at the same horsepower level?
Old Sep 2, 2005 | 05:04 PM
adseguy's Avatar
Default Re: (ramennoodles)
With all things the same compression won't move your torque...just the rod angle.
Old Sep 2, 2005 | 05:05 PM
boosted92's Avatar
The underlined/italics were trying to convey my sarcasm
I've had a 9:1, 9.3:1, 9.5:1, and 10:1 turbo setup, and the spool and off boost power was basically the same across the board, given the same bore size.
Stick with a 9:1 SCR, and focus more on the right turbocharger and cylinder head components to make the most torque. An LS @ 11:1 compression with a VictorX intake and a T3/T67 is obviously going to get shitkicked in the mid range compared to an 8:1 compression motor with a skunk2 intake and a .48 A/R SC34.
Old Sep 2, 2005 | 05:14 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">The underlined/italics were trying to convey my sarcasm
I know you were, I was agreeing/re-iteratting (spelling is totally wrong )
Old Sep 7, 2005 | 09:55 AM
Lsos's Avatar
Default Re: choosing piston compression for more torque (ramennoodles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking into buying a set of pistons for my ls turbo. what I wanted to know is, would it make a difference in torque at the same horsepower between 9:1 compression ratio versus a 8:1 copmression ratio? would one have more torque than the other or will it be the same? or if someone could post a link to some good info, that would be cool</TD></TR></TABLE>
Ideally it will increase your torque across the board...and unless you turn down the boost or decrease your redline, the horsepower will increase, too.
peakboosth22
Jun 20, 2006 08:55 AM
jdm2teg
Dec 14, 2005 01:41 PM
Quade
Apr 5, 2005 03:12 PM
immortal
Nov 6, 2001 08:05 AM
BLaCKWiDoWSi
Nov 2, 2001 03:12 PM
