Using a Check Valve for my MAP sensor... still throwin a CEL
Old Apr 10, 2005 | 06:00 PM
Johnny_Rocket's Avatar
Default Using a Check Valve for my MAP sensor... still throwin a CEL
Here's my situation... If i stay below 5 psi I'm good. But if I really rev it out to 6,800 at 5 psi the CEL light pops on. I know it goes into limp mode and it's because of the map sensor seeing boost. My question is... If i get another check valve or 2... or even 3 more and tee them off of the map sensor vacuum line will this solve my problem? I'm thinking the boost pressure is too much for the single check valve to handle.
Old Apr 10, 2005 | 06:03 PM
N20civicB18's Avatar
Default Re: Using a Check Valve for my MAP sensor... still throwin a CEL (JohnnyH)
I think if your not using a missing link then you need to use multiple check valves
Old Apr 10, 2005 | 06:07 PM
Default Re: Using a Check Valve for my MAP sensor... still throwin a CEL (N20civicB18)
that's what I figured... I just wanted to see if anyone else had any insite. They're like $4 a piece... So figure I'll get 2 more and see if that solves things
Old Apr 10, 2005 | 09:37 PM
PrettyLude's Avatar
man just get the missing link, it looks so much cleaner than all those check valves
Old Apr 11, 2005 | 12:04 AM
mtber's Avatar
Make your life easy & look into uberdata tuning.
I am sure there is a tuner in NY.
Old Apr 11, 2005 | 12:08 AM
96-EJ6 B18C's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Make your life easy & look into uberdata tuning.
I am sure there is a tuner in NY.</TD></TR></TABLE>
Old Apr 11, 2005 | 12:13 AM
Frozen E's Avatar
H-T White Ops
I think you need 3 of those fish tank check valves to make that setup work. Don't quote me on that though. I read a "how-to" about a year ago or so before I decided to go with Uberdata.
Old Apr 11, 2005 | 12:35 AM
blackhatchb20's Avatar
Default Re: (IslandSi)
Here is a VERY fast drawing i did in paint
but this is how its done, PM me is you have any ?'s
slowasasnail
Apr 15, 2007 06:36 PM
teggreen4
May 13, 2005 02:12 PM
Pengo
Jul 30, 2002 08:43 PM
