check engine light MAP sensor hellppp
Old Apr 20, 2006 | 06:10 PM
skip122's Avatar
Default check engine light MAP sensor hellppp
i got a check engine light on my 95 civic dx wit sohc vtec wit greddy turbo kit using the greddy blue box.. the code is sayin map sensor but my map sensor is working bc the car is running perfect an when it is runnin if i unplug the sensor the car dies ne one have ne ideas lemme kno thanks
Old Apr 20, 2006 | 07:17 PM
97turboteg's Avatar
Default Re: check engine light MAP sensor hellppp (skip122)
u need check valves or a missing link...that tells the ecu your not running boost...lemme know if you wanna buy a missing link, im selling mine...pm me if interested and make me an offer
Old Apr 21, 2006 | 12:42 PM
skip122's Avatar
Default Re: check engine light MAP sensor hellppp (97turboteg)
the thing is with the blue box it shoulnt have a check engine light bc i had the isame setup in a 93 dx an it wasnt on how much u want for ur missing link
Old Apr 23, 2006 | 06:27 AM
97turboteg's Avatar
just give me an offer man, im also trying to sell a paxton FMU, stock used pistons and rods, and stock valve springs...give me an offer on the missing link
Old Apr 23, 2006 | 07:34 AM
Trailz-EX's Avatar
the blue box should intercept your map signal to your comp and tell it your not boosting. tricks it(kinda like a check valve or missing link accept its electric). your map sensor can only read i think 10 or 11 psi. if the comp sees more than one psi it will throw codes. maybe your blue box isnt working. or your waste gate isnt opening and your over boosting. boosting past what the blue box can hadle and its sending +psi signals to your comp
eaz_e
May 15, 2009 05:03 AM
skip122
Apr 21, 2006 12:43 PM
Blanket Jackson
May 25, 2004 07:59 PM
incognitoracerr
Jul 14, 2003 06:17 AM
Blackcivic1
Nov 4, 2002 04:03 AM
