cheat the hack!
Old Dec 28, 2003 | 05:43 AM
rudebwoy's Avatar
Default cheat the hack!
is there anyway I can run 20 psi on the afc hack? fmu? extra injectors?
Old Dec 28, 2003 | 07:16 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: cheat the hack! (rudebwoy)
you can run 20 psi with 440cc injectors,12:1 fmu,check valve,and an afc.pm me for details
Old Dec 28, 2003 | 07:19 AM
Burke's Avatar
Banned
Default Re: cheat the hack! (turbotypeR)
its not the safest, but has been proven to work
good luck with it.
if you are obd1, check out uberdata - its pretty cool
Old Dec 28, 2003 | 04:51 PM
VNTEC's Avatar
B A N N E D
Default Re: cheat the hack! (Burke)
I thought u could get a 3 bar map sensor to allow for higher boost?
Old Dec 28, 2003 | 05:15 PM
TeStUdO's Avatar
Default Re: cheat the hack! (VNTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC &raquo;</TD></TR><TR><TD CLASS="quote">I thought u could get a 3 bar map sensor to allow for higher boost?</TD></TR></TABLE>
Well you can, but he wants to "cheat" the Hack. I guess he doesnt want to get a 3 bar MAP sensor.
Old Dec 28, 2003 | 05:20 PM
BoostedITR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">you can run 20 psi with 440cc injectors,12:1 fmu,check valve,and an afc.pm me for details </TD></TR></TABLE>
yup I am runnin this set up on my car now. get that inline pro head gasket and block gaurd if you are on stock internals. definatly a better set up than the hack.
Old Dec 28, 2003 | 06:24 PM
25 Year Member
Default Re: cheat the hack! (BoostedITR41)
if you install a check valve inline with the map sensor correctly,you can make as much boost as you want.all you are doing with"the hack" is making the ecu think there is no boost.if you do the check vlave,it will do the same thing,except you can go above 10-11psi.add in a fmu and you can get enough fuel to make more boost.
Old Dec 28, 2003 | 09:38 PM
rudebwoy's Avatar
I have JE pistons9.0.1 comp., Eagle rods, cometic 1.7mm headgasket, AZ blockguard, and arp studs, so I can just add the missing link and be good or do I have to get an fmu? everone on the HMT board said check valve/missing link dont go with afc. please explain any sacrifices, and what to expect, or will adding the 2-3 bar sensor map sensor better?
LSej1
Jul 19, 2008 03:51 AM
DrivinVtec
Jul 8, 2007 01:01 AM
vg7z
Sep 12, 2006 07:20 PM
Topdawgg
Jan 18, 2006 05:15 PM
vu337
Oct 24, 2005 04:50 PM
