CEL with the missing link
Old Feb 23, 2004 | 11:31 AM
CiViC SiR's Avatar
Default CEL with the missing link
hi guys,
i'm getting CEL when ever i shift to 3rd gear, i never had this problem befor.
i'm using a missing link and boosting @ 15psi
Old Feb 24, 2004 | 05:26 AM
CiViC SiR's Avatar
Default Re: CEL with the missing link (CiViC SiR)
any help
Old Feb 24, 2004 | 03:26 PM
Distorted's Avatar
Perhaps either to much or not enough fuel. The missing link only eliminates the map sensors issue with over pressurization. At the maximum boost the map sensor can handle, the ecu has a certain range of fuel its searching for through the O2 sensor. If it thinks you have to little, cel. If it thinks you have to much for this theoretical pressure, then again, cel. Because your pushing 15psi when the map can only really comprehend 10.25 roughly, it most likely thinks there is to much fuel. Something I learned from moding a Volvo S70 is that they inject air into the exhaust system before the secondary O2 sensors, to adjust the value and pass emissions, you could work a system out like that. Though its needlessly complicated and I'd suggest just finding out how much boost you can run without getting a cel.
Old Feb 24, 2004 | 11:45 PM
Nick7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR &raquo;</TD></TR><TR><TD CLASS="quote">hi guys,
i'm using a missing link and boosting @ 15psi</TD></TR></TABLE>
Umm... what kind of fuel management can support 15psi when using missing link???
Old Feb 26, 2004 | 02:27 AM
CiViC SiR's Avatar
Default Re: CEL with the missing link (Nick7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick7 &raquo;</TD></TR><TR><TD CLASS="quote">
Umm... what kind of fuel management can support 15psi when using missing link???</TD></TR></TABLE>
Original ECU
Old Feb 26, 2004 | 05:45 AM
Nick7's Avatar
Original ECU</TD></TR></TABLE>
Plase elaborate.. what you use besides missing link for fuel management?
Old Feb 26, 2004 | 06:16 AM
turbotypeR@SPEC's Avatar
25 Year Member
i have seen missing links not able to do over 11psi.i can hook you up with a check valve that would be good up to 120psi
Old Feb 26, 2004 | 06:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Plase elaborate.. what you use besides missing link for fuel management?</TD></TR></TABLE>
::all ears::
Old Feb 26, 2004 | 06:33 AM
Nick7's Avatar
Default Re: CEL with the missing link (DaX)
Hmm.. OK, found what u use:
https://honda-tech.com/zerothread?id=760336
.. so you basically use AFC hack.. you use modified ECU.. you use 3-bar MAP sensor... AND you use missing link?!?!
OMG... this is what I call a 'mess'...
Old Feb 26, 2004 | 06:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
3 bar map and missing link...what's the point?
Old Feb 27, 2004 | 11:59 PM
CiViC SiR's Avatar
S-AFC
Old Feb 28, 2004 | 12:05 AM
CiViC SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick7 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm.. OK, found what u use:
OMG... this is what I call a 'mess'...</TD></TR></TABLE>
thats my car (the yellow civic) i dont have problem with that, the problem is in my friends car
elpiar
Mar 22, 2005 06:02 PM
94greddycivic
Jun 29, 2004 10:51 AM
spark plugs.
May 18, 2004 06:36 PM
Integra_Boi
Oct 22, 2003 07:55 AM
TurboLude97
Apr 30, 2003 05:12 AM
