CEL misfire code.....
greddy turbo on my 00 Si keep getting that code...i have reset it several times but it keeps coming back. Im running the greddy blue box and 7 heat range plugs.
any ideas guys?? |
Re: CEL misfire code..... (spoolin_si)
Any other codes? Generally isfire codes come from other problems that may themselves throw codes. If not, you may just need to tighten the gap some.
Re: CEL misfire code..... (beepy)
or it could be worse - ringland failure will throw misfire codes, I know first hand. http://images.honda-tech.com/set1//smile/emcrook.gif
what is the plug gap you're running? you might want to do a quick compression test just to check the general condition of each cylinder. |
Re: CEL misfire code..... (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">or it could be worse - ringland failure will throw misfire codes, I know first hand. http://images.honda-tech.com/set1//smile/emcrook.gif
what is the plug gap you're running? you might want to do a quick compression test just to check the general condition of each cylinder. </TD></TR></TABLE> 100% correct, and I had the 18g kit back in 2002 |
