CEL - Map Sensor... Please Help
Old Feb 4, 2003 | 01:14 PM
Sivik's Avatar
Default CEL - Map Sensor... Please Help
Hey,
I was driving around and my CEL came on. Did the home test w/ a paperclip and got the DTC Code 03. From jdmfan.com:
03 Manifold Absolute Pressure sensor Open or short in MAP sensor circuit, defective MAP sesnor
So what now? I have a 98 EX with the 92-95 GReddy kit on there. Haven't touched the boost setting at all. Any ideas on what I have to do? Thanks!
Old Feb 4, 2003 | 01:17 PM
sgT's Avatar
sgT
Default Re: CEL - Map Sensor... Please Help (Sivik)
how much boost?
are you using the blue box?
Old Feb 4, 2003 | 01:27 PM
Sivik's Avatar
Default Re: CEL - Map Sensor... Please Help (sgT)
Stock boost (5.5 psi)
Blue Box - Yes
Old Feb 4, 2003 | 01:42 PM
badCRX's Avatar
New User
Blue box doesn't work all the time for some reason. Disconnect battery and then reconnect to reset ecu and be on your way. I have never had good luck with the Missing Link check valve, but they have worked well for others. Try that if you may.
xiLLtegRax
Apr 28, 2008 08:19 AM
Boosthead
Jan 5, 2005 07:40 PM
kell211
Oct 7, 2003 05:39 PM
Daniel
Feb 11, 2003 11:19 AM
Blackcivic1
Nov 4, 2002 04:03 AM
