CEL - Map Sensor... Please Help
Hey,
I was driving around and my CEL came on. Did the home test w/ a paperclip and got the DTC Code 03. From jdmfan.com:
03 Manifold Absolute Pressure sensor Open or short in MAP sensor circuit, defective MAP sesnor
So what now? I have a 98 EX with the 92-95 GReddy kit on there. Haven't touched the boost setting at all. Any ideas on what I have to do? Thanks!
Blue box doesn't work all the time for some reason. Disconnect battery and then reconnect to reset ecu and be on your way. I have never had good luck with the Missing Link check valve, but they have worked well for others. Try that if you may.
Boosthead
Jan 5, 2005 07:40 PM
