CEL help
Old Dec 5, 2001 | 03:28 PM
98Psi ITR's Avatar
Default CEL help
1106
1456
Old Dec 6, 2001 | 08:56 AM
98Psi ITR's Avatar
Default Re: CEL help (98Psi ITR)
up
Old Dec 6, 2001 | 09:01 AM
downpipe's Avatar
i can check when i get home in a few hours....
Old Dec 6, 2001 | 10:05 AM
98Psi ITR's Avatar
Default Re: CEL help (downpipe)
thanks.
Old Dec 6, 2001 | 05:12 PM
downpipe's Avatar
are you sure those codes are correct? i have the helms manual for 96 integra gsr. i couldnt find those codes anywhere. i thought that most codes are pretty much standard... are they different for the ITR? sorry i couldn't help.
Old Dec 6, 2001 | 05:55 PM
Arturbo's Avatar
Better than steak
25 Year Member
Per the Helms manual:
1106= 13= Barometric pressure circuit.
1456=90= Evap. Emission controll system leak detected(fuel tank area)
Old Dec 6, 2001 | 06:38 PM
Mikex25's Avatar
New User
Default Re: CEL help (Arturbo)
I also have a CEL 90 but I can't figure out how to fix it.
Old Dec 6, 2001 | 07:04 PM
HXMan's Avatar
Default Re: CEL help (Mikex25)
Are you using your cars stock ECU? What car are you driving and what swap do you have(if you have a swap)?
Old Dec 6, 2001 | 07:19 PM
fixhondas's Avatar
Default Re: CEL help (HXMan)
is this a 98 type R?
1456 can be caused by loose gas cap, a leak in the tank, or contaminated 2way valve/ bypass valve/ tank pressure sensor. It depends on which setup your car has.
Baro sensor is inside the ECU- could be a false code- I'm nit sure on how the ECU monitors this sensor. It may compare map to baro and if the baro is lower than map it might cause this.
Old Dec 7, 2001 | 11:12 AM
98Psi ITR's Avatar
Default Re: CEL help (fixhondas)
yes its a 98 type R and I couldn't find them in the Chilton book.
thanks guys.
Old Dec 8, 2001 | 02:53 PM
98Psi ITR's Avatar
For my Cel 1456, one of the wires for the charcoal canister was cut off from the harness. Soldered that bad boy back, but the 1106 I don't know how to fix.
Old Dec 8, 2001 | 09:00 PM
downpipe's Avatar
why couldnt i find those codes in my helms manual? am i a loser or are they different for the type r, or was i lookinging in the wroung place?
Old Dec 8, 2001 | 09:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you look in the helms they have a 4 digit number then the single #...Look very carefully..
Old Dec 9, 2001 | 07:15 AM
downpipe's Avatar
mine says 1107=13, and i can't even find the 90! grrrrr...what the hell is going on?
mugencivic94
Oct 26, 2006 10:36 AM
VinceVTEC
13
Nov 22, 2004 05:43 PM
Black Si
May 4, 2004 04:57 PM
ITR9788
Apr 22, 2004 01:44 PM
Civic89
Jun 27, 2002 12:20 AM
