6 CEL codes. Help
Old Apr 22, 2004 | 01:14 PM
ITR9788's Avatar
Default 6 CEL codes. Help
I am throwing 6 CEL codes.
p0325
p0172
p1337
p0453
p0450
p0170
If anyone knows what these codes are and how to fix them, it would be appreciated. Thanks.
Old Apr 22, 2004 | 01:22 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 6 CEL codes. Help (ITR9788)
I thought the CEL codes are two-digit codes...
Old Apr 22, 2004 | 01:30 PM
ZygSpeed's Avatar
P0325 -- knock sensor circuit malfunction
(open or short in knock sensor, knock sensor problem or ECM/ECU)
P0172 -- system too rich
(fuel supply system, primary HO2 sensor, MAP sensor, contaminated fuel, valve clearance, or exhaust leakage)
P1337 -- crankshaft speed fluctuation sensor (CKF sensor or signal circuit)
P0453 -- ?? didn't see/find this code number in the manual
P0450 -- ditto
P0170 -- also not found.
The above are from my 96 Teg manual. Ed
Old Apr 22, 2004 | 01:33 PM
ITR9788's Avatar
Thanks. Anyone with the other 3?
Old Apr 22, 2004 | 01:35 PM
ZygSpeed's Avatar
Default Re: (ITR9788)
What symptoms is the car exhibiting?
Other one might be fuel tank vapor pressure, etc. which were not part of my OBD system.
Old Apr 22, 2004 | 01:44 PM
ITR9788's Avatar
Default Re: (zygspeed)
Well, I just finished putting my fully built motor together(installing my turbo in a couple of weeks). After about 20 minutes the cell light came on. I am breaking it in with the stock ecu and odb1 injectors. I am running an AEM adj. FPR though. It seems to be running fine.???
lmike6453
Oct 29, 2009 06:02 PM
oranginal
Jul 6, 2006 02:17 PM
CivicESi
Nov 20, 2003 07:25 AM
EVIL_AWD
Oct 9, 2003 08:18 PM
Leisyman
May 6, 2003 09:35 AM
