Catch can questions...
Every motor is different, some will have more blow by then others. Especially if its a build motor. If you have a healthy stock motor you probably won't get as much blow by, so you can probably get away with the valve cover kit.
Ok, so I talked to Tony and he said I would be good with just the valve cover one (Which I would like because I just think it would be easier... but I have a ramhorn manifold so I cant do it off the front of the vc but I was reading that the back of the vc isnt baffled so more oil comes out, will I fill the can quickly if I do it off the back?
yea back of the valve cover isn't baffled, some people run fitting of the back but I don't like it. Never tried it, might work, might not. You still might be able to run in from the front of the valve cover, it depends on the manifold. Sometimes it can be a bitch but you can move the fittings around to make room. Make sure you test fit stuff 10 times before cutting into the valve cover.
I bought this one a year ago for 53 shipped brand new. http://jdmultimate.com/Store/Product...Make=UNIVERSAL
Put 2 filters on top. I'm running 2 -12 lines from the back of the valve cover, the one clear line back to the back of the block. Took some modding of the can but it looks and works well. I'll try to post a pic if I can figure it out.
My can isn't baffled. I heard of putting steel wool in the can to baffle it. But I don't see what the point is, unless you were off-roading. I change my oil religiously so I don't worry about it draining back into the motor. I have a clear tube running back into the block and it was a while before I even seen oil residue in the drain tube.
nonpoint986
Feb 20, 2010 10:45 AM
SequenceGarage
Welding / Fabrication
13
Dec 30, 2006 01:14 PM
hondalawnmower
May 30, 2002 04:32 PM
